Home > Maintenance & Modifications > Pre wired LED fog and reverse lights
Crs90
Evening all, does anyone know of a supplier that sells the pre wired (plug) fog and reverse lights ? All the ones I have seen so far just have a couple of wires loose.
Post #576609 9th Nov 2016 9:13pm
Not that I'm aware of but I'm sure someone here may be able to for you if that is what you want? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #576630 9th Nov 2016 10:05pm
Martin
Site Admin
Which lamps are you after?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #576631 9th Nov 2016 10:07pm
Crs90
I am after a replacement LED fog and reverse light that will plug and play if possible, in original colours to go with the Wipac LED sidelights and indicator lights I have.
Cheers Chris
Post #576642 9th Nov 2016 10:22pm
Martin
Site Admin
Which lamps do you currently have?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #576652 9th Nov 2016 10:44pm
Crs90
Hi Martin I just have bog standard lights throughout at the moment but have a Wipac led set ready to go,
Post #576788 10th Nov 2016 1:41pm
nakatanenga
Germany
Post #576826 10th Nov 2016 4:18pm
Stacey007
Hello
I got mine here he does clear and coloured, also metal plinths if needed, these are the larger NAS Style.
Have to say in this weather they are 100% improvement over standard when on. Plug straight on with correct leads.
Post #576839 10th Nov 2016 5:03pm
dorsetsmith
two types fog and reverse lights fitted to defenders from LR excluding MOD Exclamation Square and round type and also two type connectors
Post #576846 10th Nov 2016 5:49pm
Crs90
Cheers for the replys I'll get a lamp taken off this weekend and see what type of connections are fitted
Post #576994 10th Nov 2016 11:07pm
HardCharger
I think MudUK sell them with sockets.
Post #577026 11th Nov 2016 4:58am
