Home > Technical > 2013 110 Clutch
Page 2 of 2 <12
Tumbiri
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Thanks!
Do you have a PN for the latest clutch? My Defender is a 2013 Puma 2.2L.
Post #579312 20th Nov 2016 11:05pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
ickle wrote:
Complete new clutch assembly latest type to include bearing in end of flywheel
New slave cylinder/realease bearing unit - latest type PLUS Matching valve
And whilst its out gearbox / transfer box adapter shaft - be rude not to....
any guidance on where to buy these bits? brands to look for? V8 90...WIP
Post #582034 1st Dec 2016 11:08pm
Tumbiri
I buy all my parts on-line from Rimmer Bros.
Post #585567 16th Dec 2016 1:59pm
Tumbiri
Thought I'd update the thread with the findings.
In the end it came down to a disintegrating pilot bearing in the flywheel. Took the opportunity to renew the clutch assembly, slave cylinder/release bearing, slave cylinder adapter and valve.
Sometime ago the gearbox was dropped to get to an oil leak. Suspect that on reassembly the clutch assembly may not have been aligned correctly and was the ultimate cause of the bearing failure. Any comments?
After everything was put back I found that the gear shift lever would not freely move to the neutral position when coming out of second to go into third. Also more vibration than normal is being felt in the gear lever. It freed up after a while and with the engine running the lever would center. However, with the engine off the lever will not center on its own. Any ideas what may be causing this?
Post #624751 17th May 2017 1:32am
agentmulder
Kuwait
Could just be the 'whatzit' that holds down the lever ball joint itself. Take off the boot and have a look, 4 bolts.. you should figure it out Thumbs Up
(Why oh why does it have 4 bolts instead of 3 that's another question...) Solved the bowel problem, working on the consonants...
Post #624753 17th May 2017 3:03am
Page 2 of 2 <12
