![]() | Home > Puma (Tdci) > help 2010 puma engine missing |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
If your anyway near Halifax give Stonelake a call
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4741 ![]() ![]() |
This might be stating the obvious. You stated that the problem started after a service. If they changed the diesel filter did they fill the replacement with diesel prior to fitting it? If not there could be air in your fuel system and it could need primed. 1982 88" 2.25 diesel
borntohunt Member Since: 30 Oct 2016 Location: yorkshire Posts: 2 ![]() ![]() |
Turns out it was the regulator that I had purchased cheaply of e-bay £40 that was faulty. After fitting a new land rover one all is back ok now . Expensive lesson learnt
