![]() | Home > Puma (Tdci) > LED reverse light |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Worth a check of Fuse 10 in the battery fuse box, which is the one under the RH seat.
Steve W Member Since: 30 Mar 2014 Location: West Sussex Posts: 224 ![]() ![]() |
Yes checked fuse was the final check I did ....... Still no joy !
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I had to change the switch on mine. Not long after fitting the led reverse light too. Maybe he bulb reverse light is less sensitive than the LED unit. Cheapest place for the switch surprisingly was Land Rover. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Ok cheers Roy I'm hoping to push through as warranty
Double post so deleted ......
99,99% the cause is the reverse switch on the gearbox..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Booked in dealers for this Tuesday, will let you all know what they say / find
