![]() | Home > Td5 > engine size |
2.5 ltrs Roel
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Yup that year all diesel engines were all 2.5 litre. If it is a four cylinder it is a 300 Tdi, if it has five cylinders its is a Td5. The Td5 is distinguishable by a large square black plastic cover over the entire engine the Tdi has a black rubber mat over the valve cover only. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
said00212 Member Since: 28 Oct 2016 Location: LONDON Posts: 5 ![]() ![]() ![]() |
HELLO AGAIN NICE OF YOU TO REPLY IT MUST BE A 300TDI AS ITS A 4 CYLIDER ENGINE AND NO TOP BLACK COVER
MERCI BEAUCOUP |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
Just for interest, you can check what DVLA think it is, as well as a few other bits of info.... https://vehicleenquiry.service.gov.uk/Default.aspx
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2953 ![]() ![]() |
Heavens, you bought an old Land Rover and don't know what engine it has?
That's brave! I hope the rest of it is OK! |
i cknow verry brave
with you guys on my side shouldnt be a problem unless i get hit by lightning |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2283 ![]() ![]() ![]() |
A picture speaks a thousand words Said, post a picture of the engine and we should be able to confirm it for you 😊
