Home > Puma (Tdci) > Engine trouble |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I use Ivor Searls for bare engines, I've recently replaced one in a 2.4 transit.
Bare block, simply bolt on your existing ancillarys, injectors, turbo etc. They come with new fuel pump, and a timed up ready to run. These come in at around £2500/ £3000 + vat depending on model. £800 surcharge on old unit. Some may be cheaper, but I would be weary of quality issues. I just had a customer drop off a recon TD5 head for me to fit, and in all honesty it looks like it's just a second hand head off of a breaker! I wouldn't say it's had any work done, other than a rubbish paint job, which just blew off with an air line!! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
20th Oct 2016 4:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17391 |
I would second Ivor Searles.
20th Oct 2016 6:15pm |
jack01986 Member Since: 20 Oct 2016 Location: Dublin Posts: 5 |
Thanks for that guys will check him out.
21st Oct 2016 8:22am |
So the mechanic is fairly sure that the turbo was failing and managed to draw all the oil out of the sump and one thing led to another.
21st Oct 2016 5:07pm |
Is it a big job to fit the 2.2 puma engine into the car instead of the 2.4? Id imagine the ECU might need to be updated anything else?
24th Oct 2016 11:57am |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
Big job, ecu / ABS has to be changed different Ipac and wiring.
I looked at this and decieded to stick with 2,4 for ease of replacing my engine. "Rafiki" 2007 110 STW - Rolling rebuild. |
24th Oct 2016 10:01pm |
Well the diagnosis seems a bit better. Not too much damage to the block and no valves having dropped into the engine. It seems the timing chain slipped. Is this common? He thinks the injectors and turbo might be ok. The only way of knowing would be to put it all back together and see. What do you guys think. Where would one source new injectors?
11th Nov 2016 3:50pm |
