Home > Technical > Springs.
Page 2 of 3 <123>
jst
are the later 11MY springs on 90s and 110 not a stronger rate anyway for the N1 requirements? ie compared to the pre 11MY Def which i believe used the same springs across the model range as td5 Defs. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #51791 8th Jan 2011 6:00pm
RED-DOT
Wear is when something loses matierial causing failure and coil springs over time go weak but don't wear. I had a new TD5 that would bottom out with 500kgs in the back. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #51792 8th Jan 2011 6:00pm
jst
cheers. i expect the 'confusion' has arisen where you have used the tech def for wear where as i epxect the OP was just expressing it as a term. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #51794 8th Jan 2011 6:02pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
jst wrote:
From what i remember CSW ones are dual rate as you say, other spec ones aren't. i presume you have a non SW TD5 then? This is the case for 90s, i think the 110s are now the same SW or USW etc.
Yeh i have a County hard top as i dont need to carry any passenger, only dogs and tools mainly but during harvest i normally have 200 litres of adblue in there too for the tractor.
Pete.
Post #51795 8th Jan 2011 6:07pm
RED-DOT
Zinke, why not look at the Puma 90 CSW springs as they are now HD as standard? Much improved. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #51797 8th Jan 2011 6:11pm
Zinke
Thats what ive been asking about! lol
I dont want a HD spring though, if they are changed for the 2011 MY to HD springs then i will get the 2010 MY springs if there is a difference. Just wondered if anybody else has done it or just making sure they are Duel rate and wanting to know when they where changed!
Pete.
Post #51799 8th Jan 2011 6:22pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
my 10MY came with HD springs - way to hard for my light loads so i have swapped them for standard road springs
i still have the HD springs just in case but to be honest i don't think i will be needing them in the future. the most i carry on the back is occaisionally 2 very large sons [one is 17+ stone rugby nut] and it does'nt drop much at the back as far as i can see.
apart from a smoother ride the only other difference is cornering, it cornered flatter with the HDs.
i put on -
90 4 seat station wagon (2400 Kg)
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
took off -
90 4 seat station wagon (2550 Kg)
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple BM52
Post #51800 8th Jan 2011 6:24pm
Zinke
i put on -
took off -
Perfect! Just what i was looking for with part numbers too! Many thanks!
Pete.
Post #51801 8th Jan 2011 6:27pm
Lorryman100
THIS any good to you?
Post #51820 8th Jan 2011 7:16pm
Zinke
Yeh thats handy thanks!
Pete.
Post #51823 8th Jan 2011 7:23pm
discocuzzy
Red Dot srikes again!! Rolling with laughter
OME 751 on the front, 755 on the rear for me, still using standard shocks but lifts about 40mm due to the stiffer nature over the standard LR...ride can be a bit firm though unless you have a rack, drawer system etc.
Suits it though, goes round corners like a sports car Whistle You cannot teach stupid people to do clever things
Post #51826 8th Jan 2011 7:28pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
-Topic Hijack- ! Mr. Green
Hi
I bought last week a pair of front springs - 110 HD NRC9448 and NRC9449. However on the board that Lorryman1000 posted it's written, among other things - Front drivers side and fornt passenger side - As my 110 is a LHD vehicle should I switch sides when I fit them ?
Thanks Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #51834 8th Jan 2011 7:44pm
Glynparry25
Hi
Thanks
Yes.... the Driver side one tends to be either a little stiffer or longer (can't remember which) to make up for the fact you ALWAYs have someone in the Drivers seat.... Makes the Landy sit straight when driving.
Glyn Sheep
Post #51836 8th Jan 2011 7:48pm
lrmaniac
Thanks Glyn ... It makes sense ! Thumbs Up That was my idea, but it's always good to check!
Going to have them fitted next friday ...! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #51839 8th Jan 2011 7:55pm
Zinke
i put on -
took off -
Just another quick question, are the new ones you put on duel rate springs or not? Just looked at the puma manual and it says only the 90's with HD springs are duel rate but i thought it was all the CSW springs.
Many thanks
Pete.
Post #51876 8th Jan 2011 9:10pm
Page 2 of 3 <123>
