Home > Off Topic > Which Peugeot Diagnostic Tool? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
I have PP2000 (for Peugeots), Lexia (for Citroens) and Diagbox which does the diagnostics for all. It all comes packaged together. You need the correct interface from ebay too.
Be aware that a lot of interfaces are Chinese rubbish which are ruined by a forced firmware update the first time you run the software. Steve 02' 110 TD5 Double Cab Rebuild Thread |
26th Oct 2016 11:36am |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
I realise this isn't a particularly helpful comment, but I was looking through the coverage list of my Autel MD802 (which does cover Peugeots and is easy to use) and it lists "Driving School Module" as one of the ECUs it covers. What on earth does that do?!
Anyway, the MD802 lists "Under inflation detection" as one of the ECUs that it can talk to an a 207, read and erase faults and view live values. The MD704 should be slightly cheaper and limits itself to European cars. There are four MD700 series and they're combined in to the MD802. I got my MD802 on eBay for about £170. The big limitation with that series of tools is they can't write new data to the ECUs and that's fairly common with the more affordable ones. That means you can't use them to programme a new key for for instance. |
26th Oct 2016 1:40pm |
Driving school module fits on the passenger side of the dashboard and provides warning lights and a speedometer for the driving instructor so they don't need to keep looking at the instruments.
26th Oct 2016 2:35pm |
Thanks. That makes sense. |
26th Oct 2016 3:15pm |
No problems, I am a bit of a Peugeot geek
The Lexia/PP2000 interface is the hardware/software the dealer uses. It can perform any dealer function. I have successfully used it myself to read HVAC fault codes, configure ECU/BSI options and program new keys. Steve 02' 110 TD5 Double Cab Rebuild Thread |
26th Oct 2016 3:26pm |
