Home > In Car Electronics > Rear door courtesy light switch
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have tried a search but all relevant diagrams are too old to download
I wish to operate a new interior light in the back of my 90 with a new rear door courtesy switch - nothing there at present
Also no factory fitted alarm (although lots of other security layers Very Happy )
Could someone please explain the wiring for the light through a rear switch
Some posts say the switch is the earth but the interior lights have two purple wires and one black wire so I am confused
Also what controls the dimming of the light and if its the ECU do I need to take a live feed from there ?
Any advice greatly appreciated
Post #571283 16th Oct 2016 5:45pm
grafty99
One purple wire is alarm controlled live with door open. One purple wire is permanent live and the black is earth. The rear door switch needs to be the same as the front, single wire earthed when door open. You can tee into the passenger door switch wire or there might be one running up the drivers side a pillar under the plastic trim... 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #571293 16th Oct 2016 6:14pm
grafty99
Hope that makes sense? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #571294 16th Oct 2016 6:16pm
boode
Makes sense - but still confused
From back door an earth wire will run through door switch up to light ?
Permanent live easy to wire in
Purple with white line - live when door open - how do I re create this for the back door ?
Post #571300 16th Oct 2016 6:28pm
grafty99
The earth wire for the trigger needs to be wired to the wire that runs to the back of one of the front door switches. Then the two purple wires need to be connected to the lamp. This way the rear lamp will come on / fade off as per the front. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #571340 16th Oct 2016 7:59pm
dorsetsmith
Post #571359 16th Oct 2016 8:31pm
boode
Thanks for the diagrams
Post #571368 16th Oct 2016 8:41pm
