Home > Td5 > Bulkhead swap
Page 2 of 2 <12
excossack
Hi I only have the last pic in the first post that shows the two pointy lugs.
If you want a hi-res picture i can email one over?
When I get the old bulkhead back I can take some more pics for you? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #572124 19th Oct 2016 7:45pm
mk1collector
If you could take a pic or two when you get the old bulkhead back it would be much appreciated. I will be replacing my windscreen surround in the next few months so a couple of pics would be a good heads up Thumbs Up Ray
My build thread
Post #572171 19th Oct 2016 9:02pm
excossack
Saw the 110 to day, Wings on and aligned, bonnet, grill all back on. Windscreen frame back in place - just needs bolting down and glass going in.
Hopefully back with me tomorrow.
@Mk1Collector - do these pics help?
Regards
John M0VAZ
Post #572536 21st Oct 2016 5:54pm
mk1collector
Absolutely perfect thanks Thumbs Up gives me a good idea of what I'll be up against when swapping mine out. Ray
My build thread
Post #572559 21st Oct 2016 7:55pm
excossack
No worries, As you can see a bit of rust. Was offered £100 for it...not sure, I think it might be worth more. 1999 Defender TD5 110
Regards
John M0VAZ
Post #572570 21st Oct 2016 8:44pm
excossack
110 is back!
Just two issues. Radio not working and washer jet on drivers side not working.
Radio fixed but the washer jet, I think the pipe has come off and is leaking.... Sad
Apart from that all good.
Plus I got to drive a TD5 110 with a slick shift fitted = Smile Smile deffo on my list of mods. 1999 Defender TD5 110
Regards
John M0VAZ
Post #572702 22nd Oct 2016 6:06pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Mk1collector, this is my Defender 2001. I had the frame out and was thinking these might help you:
Apologies for the upside/sideways images. I blame Photobucket!
[/img]
[/img][URL=]
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #573353 25th Oct 2016 6:43pm
mk1collector
Excellent thanks Thumbs Up just a quick question, did you unbolt the roof any further back or just around the screen surround? Ray
My build thread
Post #573431 25th Oct 2016 10:27pm
MC84
I'm changing the thick black rubber/foam strips at the back running under the tub so I unbolted or loosened all of the rear ones as well. I think you need to do this anyway to allow clearance for the screen/frame to fall into the cab slightly so it can be lifted off the locators/pegs. Mike
Ford 100e 1959
Post #573463 26th Oct 2016 8:05am
excossack
I think when mine was done, at least the bolts for the front of the roof got removed which I think gives enough movement to remove with out undoing all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #573465 26th Oct 2016 8:12am
MC84
Good to know for next time. Thumbs Up Mike
Ford 100e 1959
Post #573466 26th Oct 2016 8:19am
mk1collector
Thanks chaps Thumbs Up I just need to line up a soda blaster to clean my replacement frame now as the soda blaster I had lined up has decided he only does large onsite jobs now Rolling Eyes I think it will be next year when I get the job done now. Ray
My build thread
Post #573486 26th Oct 2016 10:32am
Page 2 of 2 <12
