![]() | Home > Tdi > 300Tdi Power Steering Pump Noise |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
I too have a groan on left full lock when manoeuvring slowly, no leaks obvious. Jeff
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 ![]() ![]() ![]() |
It is not good practice to hold the steering wheel hard over on full lock ....you are making it groan!
Once you have vehicle on full lock just let the steering wheel come back an inch - you wont loose any lock and your not trying to power the steering box to move as its already on the stops. |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
^^^ whs.
Seabreeze Member Since: 23 Mar 2016 Location: Suffolk Posts: 48 ![]() ![]() ![]() |
Many thanks all!
jr1104 Member Since: 05 May 2016 Location: England Posts: 78 ![]() ![]() ![]() |
I have the same 'issue' on mine, and after some research and learning about how the steering system works the conclusion seems to be it just does it. As suggested, don't hold it against the lock and you won't notice it! I've also found it only ever does it when turning left.
