![]() | Home > Puma (Tdci) > Safari Snorkel |
--defender-- Member Since: 22 Apr 2010 Location: South Coast Posts: 90 ![]() ![]() ![]() |
They're great, I just need to consider the N/S more as I have that mirror landscape. I wouldn't go green-laning in them! Not a five minute job changing them as you need to take the door skin off and remove one side of the door hinge to get to the back of it to remove the screws holding the stalk base.
You don't need a step-drill, just need 3.5, 5 & 7mm twist drills. If it ain't broke don't fix it! |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Ok, cheeers for that
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Back on the Safari / ITG discussion, it seems that my combination of Safari - ITG - Allisport Intercooler - Twisted Straight Through Exhaust, all running with a BAS map gives too much airflow at motorway speed resulting in a loss of power and MIL light coming on. This is fixed by installing a standard filter.....
However keen I am on my ITG, it seems it has to go! ![]() |
