Home > My Defender > 110 Td5 Station Wagon County |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Was that the eBay one on a galv chassis? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
24th Sep 2016 3:04pm |
Welcome, Looks like a good starter, look forward to the updates 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
24th Sep 2016 3:34pm |
qxl Member Since: 23 Sep 2016 Location: Lancashire Posts: 5 |
No mate, it's on it's original chassis, but did have a new rear crossmember fitted a couple of months before I got it. |
24th Sep 2016 4:30pm |
Cheers, got a Mantec Swing away Spare Wheel carrier to fit to a virgin Rear Door. Seems a shame to start putting holes in it, but needs must and I could do with having the spare out of way. Do you know of an easy way to work out if the truck has been lifted? |
24th Sep 2016 4:35pm |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 |
Would this help you qxl?
Click image to enlarge Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
24th Sep 2016 4:41pm |
Thanks for that, might be able to work it out based on the ground clearance of the front axle... assuming I have the right size tyres. Time to get the tape measure out.
24th Sep 2016 4:47pm |
Actually thinking about it the axle clearance won't help as the suspension sits on top of it.
Of course I realized that after I'd gone out and done the measurements.. So I've got 265 tyres on 16 inch steel wheels, and the clearance was 9 inches at the front and 8 inches at the back. Some reading on suspension lifts in order I think. |
24th Sep 2016 4:58pm |
