Home > Maintenance & Modifications > Bushes, SuperPro & LR part #'s compared. Easiest?
agentmulder
Kuwait
Hello all,
Interesting creak developed last week, took a while to find, had to strap myself under the vehicle and have the missus drive us over a few cattle stops... Shocked anyhoo so it's emanating from some rear suspension and anti roll bar bushes as far as I can tell.
I think it's time to do a complete bush swap on the vehicle by now and I'm keen on the SuperPro bush kit: https://www.firstfour.co.uk/superpro-polyu...07-on.html
But I've figured out it only contains the following - (BLUE is SuperPro part#, GREEN is LR original part#):
Panhard Rod Bush Kit SPF1803K RBX101340
Front Radius Arm Rear Bushes SPF0206K ANR6971
Front Radius Arm Front Bushes SPF0195K NTC6781
Rear Trailing Arm to Chassis Bushes SPF0323K NTC9027
Rear Trailing Arm to Axle Bushes SPF0129K NTC1772
Rear A Frame Bushes SPF0128AK ANR4164
And not the rest of the bushes, which includes the ones making the noise. SuperPro do offer them however: http://superpro.com.au/find/superpro-suspe...999501465:
Antiroll bar REAR Link SPF0078K 8510241
Antiroll bar REAR Mount SPF2303-18K NRC5674
Antiroll bar FRONT Link SPF0078K 8510241
Antiroll bar FRONT Mount SPF0666-26K NTC6828
Suspension top REAR SPF0779K NRC5593
Suspension bottom REAR SPF0075K or SPF2656K RNF100090L
Suspension top/bot FRONT SPF0075K 8510240
A-framey-thingybob upper link REAR SPF0128AK ANR4164
Question:
I'm going to get the SuperPro kit so that's a given, but of those not in the kit (not bold above), which are really hard to fit without a press? I figure I'll just get the gen/OEM rubber for the easy ones... Also, the Antiroll bar mounts seem really sturdy, are they for instance necessary to swap out over time? What are the likely suspects in the second list? Solved the bowel problem, working on the consonants...
Post #565724 22nd Sep 2016 12:25am
agentmulder
Kuwait
Updated info above and made question clearer (hopefully!)
Any discussion appreciated Wink Solved the bowel problem, working on the consonants...
Post #565973 23rd Sep 2016 5:31am
Van Whalen
Australia
Re: Bushes, SuperPro & LR part #'s compared. Easiest?
Hi agentmulder,
Searching the site looking for info on A frame bushings/replacement, noticed a duplicate in your first post (A-framey-thingybob is included in the SuperPro kit in bold). Cant answer your questions, but I would like to know the answers. Anyone?! Wink
Post #629369 6th Jun 2017 7:09am
agentmulder
Kuwait
Gidday mate,
That was a while ago, I got a bunch of bushes, installed some then got busy on the rest, I'm away from the vehicle and garage for a few months too - maybe that's a typo, not sure - sorry, not much help! Solved the bowel problem, working on the consonants...
Post #629372 6th Jun 2017 7:19am
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
I'll run this through
The superpro bushes can be done with a very sturdy vice in insert and getting the old metalastiks out can also be done without a press but it makes the job 10 times longer.
I'm blessed to have a 15 ton floor press in the shed and when I superopro'd my old 90 it made the job 1000% easier.
The: Radius arms - axle
Trailing - axle
A frame upper arms - chassis
Top Rear Damper
are all single piece bushes and the ones hardest to insert. The are a snug fit but this is what makes them best on the market too.
As I said a big vice or a press makes this an easy task and i'll guess very very hard work if nigh on impossible without.
RE the rear antiroll bar bushes. I assume you mean the big 'D' shape bushes on to the chassis? If you can physically by hand move them then yes I'd consider worn but a small amount of movement in the bush itself is fine. The bush should be snug around the bar but if there is a gap then no it's worn.
Mostly it is the smaller bushes on the actual drop links them selves have play long before the main chassis ones
Post #629383 6th Jun 2017 8:12am
