Home > Maintenance & Modifications > Home made lifting roof on a 110 Land Rover
Page 2 of 3 <123>
jocklandjohn
Scotland 1989 Defender 110 200 Tdi HT Oslo Blue
I'm surprised by that. You'd think they'd be up for earning money wherever it comes from!
Post #564731 17th Sep 2016 8:57pm
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
Invoices, taxes, agreements with contracters,...
In Belgium it also depends on the TVA number you requested. Depending on that you are or not allowed to sell to a private person.
In theory I'm not even allowed to construct myself something like a rooftent for a vehicle. It must be done by an approved installer. 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #564737 17th Sep 2016 9:24pm
jocklandjohn
Ah ok - thats a real hurdle to overcome!
Didn't realise it was that restrictive over there.
Post #564740 17th Sep 2016 9:42pm
Guy
I know this post has been quiet for a long time, but just wanted to say well done! Fantastic conversion. I'm currently trying to sell my 300Tdi powered Disco 2 to fund the purchase of a Defender 130 that I'd love to convert to a station wagon with a lifting roof to sleep my family of 4.
Sadly I haven't the skills to self-build, but I think I'd still save money by asking a fabricator or conversion specialist to build me a roof rather than buying off the shelf, especially as it would include the 130 station wagon conversion.
Any more photos John?
DINGO - '99 Discovery 2 V8 with 300Tdi transplant, chawton white. Repatriated from Australia and expedition prepped.
**FOR SALE**
SHARKY - '06 Discovery 3 HSE Auto, bonatti grey. SOLD.
GEORGE - '99 Discovery 1 300Tdi Auto, willow green. Daily driver, travel companion, part of the family! SOLD.
PINGU - '96 Defender 110 300Tdi station wagon. SOLD.
Dream LR - 130 pop top station wagon camper.
Post #754248 27th Jan 2019 9:50am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I followed this build, it has a more detailed description on LR4x4
https://forums.lr4x4.com/topic/85932-110-l...ent-737994
there was a part 2 where i think he modded it even more with solid sides
Post #754290 27th Jan 2019 1:04pm
Guy
Thumbs Up
I'm gonna check out Expedition Portal too.
**FOR SALE**
Post #754306 27th Jan 2019 1:46pm
jocklandjohn
Hello chaps!
Aye the build is still going on. Glad its inspired you Guy. I'm currently fabricating hard sides that will go down the outside. The fabric is great in summer but its not so good in winter - cold, and very noisy when its windy. So I've played around with several options and the most successful is frames down each side attached to lifting roof and a cunning plan for the sealing of it and the back door 'problem' (or more simply put - how will the back door still open when the roof is down!).
More later - but here's where its heading...
[/img]
Post #754334 27th Jan 2019 4:03pm
Guy
Fantastic!
Fair play to you John!
I absolutely love my Discovery and will be sad to see it go, but there is a Defender shaped gap in my life which needs filling!
**FOR SALE**
Post #754339 27th Jan 2019 4:47pm
jocklandjohn
Well thats understandable! The Defender shape lends itself to a lot more 'tweaking'!
Post #754346 27th Jan 2019 5:36pm
jocklandjohn
So - plan for rear is to shift the spare wheel carrier rearwards a few inches. Remove the current fastened-to-and-opening-with-back-door set up, and have clips instead. The lifting roof section will come down in behind the spare wheel carrier, and will have a door that is slighty wider/taller than the existing back door and be top-hinged and on gas struts.
So to open back door I unclip the spare wheel carrier, and swing it away, turn the lifting roof door's handle and it swings up to horizontal and the original back door can then swing open as normal. And the nice touch is that the new lifted door acts as an awning over the back door. And if I'm sleeping in it with the roof down (which I do often when out working alone) I can leave the door in the up position and be able to get in and out from the back.
When the roof is lifted and you can stand up inside, the lifting rear door allows me to have a huge hole at the end up top to let air in if its really warm (Giant bug net curtain can pull across.)
So best of both worlds. And the sides/back will be 25mm thick - 4mm ply inner, 1.2mm alloy skin on a 19mm box alloy frame, with Kingspan insulation so plenty warm.
In down position the roof will be sealing against a lower lip that runs around the van, and in the up position a couple of mating gaskets and flip-over piece fior the rear (its sounds complex but in reality will be simple!).
The whole plot (i hope!) will lift on 12v linear actuators so a button press to lift and lower which not only saves my back but allows a level/even lift which redcues stress on the roof/hinges/welds.
So far I've got the side and rear frames welded, bought insulated windows, hinges, rod latches for back door, and roughly cut the alloy skins. Wee bit more welding then I can assemble and work out the actual details!
Post #754354 27th Jan 2019 6:09pm
Co1
Excellent work, well done.
Post #754360 27th Jan 2019 6:34pm
Guy
Superb!
**FOR SALE**
Post #754372 27th Jan 2019 7:12pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Awesome job, wish I had the skills to build my own
Post #754377 27th Jan 2019 7:34pm
JOW240725
Great work, very clever! James
Instagram @suffolk_rovers
Post #754386 27th Jan 2019 8:11pm
jocklandjohn
Smile to be honest the ally wedling is done by an expert - I do the design ideas and accurate measuring and cutting (chopsaw) of the bits using a wooden template then clamp the bits for the frames to the template. Thsi allows the welder do ithe welds easily and quickly. We do a wee bit at a time - I go away check it fits, come back for some more etc.
With some forethought its within most folks capabilities. I did all my work out on the drive - no fancy workshop.
Post #754410 27th Jan 2019 9:34pm
Page 2 of 3 <123>
