Home > In Car Electronics > Puma Dashboard Tweeter and Rear Speaker Cables Question
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
My 2007 110 Puma SW being a base model came without a head unit but did have the main front speakers. I've prised up the grilles on the top of the dash to find no tweeters fitted but was hoping to maybe find the wiring in place to fit some.
Does anyone know if the cables are supposed to be there or if I should be looking to take a feed off the main speakers below?
Also, I have no rear speakers fitted but was wondering if I'll find any wiring in the back to fit them or would I need to run new cabling from the front?
Any help would be much appreciated.
Cheers,
Mark
Post #564510 16th Sep 2016 2:57pm
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
I can only speak from experience of the tweeters in my own base model, the wires for them will be there just below in the dash! Thumbs Up
Post #564529 16th Sep 2016 4:42pm
^^^^ Sounds correct, but can be elusive. Probably around the lower speakers area tucked away. KEEP CALM AND Drill ON
Post #564533 16th Sep 2016 5:08pm
Lew-M
Yep the passenger side was taped to another loom behind the dash in mine, so have a good look it will be there.
Post #564565 16th Sep 2016 9:32pm
