Home > Maintenance & Modifications > Boomslang installation
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
Hi everyone,
I've just taken delivery of a boomslang headlight loom, and wondered if i could get a bit of advice from those in the know. In the installation instructions it says to connect one of the wires to either the battery + or alternator. Now to me it seems it may be easier on the alternator due to access and not needing to feed it under the car and up into the seat box, but how do you connect to this wire? Could anyone provide an explanation of how they have done this or even some pictures would be great.
Many thanks,
Lew
Post #562506 8th Sep 2016 7:37pm
VeeTee
Netherlands
Access may be different at a Td5 or Puma (mine is a 300Tdi), I just connected to the B+ terminal at the alternator (also this isn't Boomslang but similar):
 Cheers, Vincent
MySite
Post #562537 8th Sep 2016 8:21pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
Here you go fitted on the Puma - http://www.defender2.net/forum/topic35054.html
Post #562550 8th Sep 2016 8:49pm
Lew-M
Thanks chaps, much appreciated! Job for the weekend then! Thumbs Up
Post #562566 8th Sep 2016 9:17pm
Lew-M
Hi everyone,
So finally got round to having a go at installing the boomslang loom, was quite easy to install, a little bit of fiddling around but overall not too bad. I managed to get the live from the alternator as described in the post link above s thanks for that. Only issue I have is the passenger side headlight doesn't seem to be lighting up fully maybe someone could help me diagnose the issue. I thought I saw it light up fully for a moment when I first tested the lights but now remains on half lighting as you can see in the picture. Could it be the bulb? Maybe the earth on that side of the loom? Pictures below to illustrate the issue.
Cheers,
Lew
Post #565127 19th Sep 2016 5:39pm
Lew-M
Does anyone know what the black unit on the back of the wipac quadoptic headlamp does?it has a flat black connection going into it? This unit seemed loose on the lamp which isn't lighting up properly in comparison to the good headlamp.
[URL=][/URL]
Post #565154 19th Sep 2016 7:11pm
VeeTee
Netherlands
Is not it the leveling motor? Cheers, Vincent
MySite
Post #565165 19th Sep 2016 7:21pm
Lew-M
Ah ok, makes sense, thanks Vincent! Won't have an effect on the output then, I can dismiss that!
Post #565167 19th Sep 2016 7:23pm
Try a different earth point for the affected headlight, check contiunuty whilst your at it and compare to the other. $W33T $0U7H3RN $UG4R
Post #565170 19th Sep 2016 7:25pm
Mwd
Same problem with mine, only on the drivers side. Worked fine for a few weeks and then I had both main and beam filaments half illuminated on one side. I reconnected the original headlamp connector on that side and now need to find the time to find the fault. Earth seems to be the likely consensus but I don't know yet!
Post #565370 20th Sep 2016 12:48pm
Lew-M
Going to have a mess with the earth tonight as per Steve's suggestion so will report back to see if this sorts it!
Post #565379 20th Sep 2016 1:27pm
Lew-M
It was indeed an earthing issue, switched the earthing point and all is well now. Great improvement on standard, much brighter, and atleast I have piece of mind in the knowledge that my switch should be alright going forward. Time to order some wipac crystals Thumbs Up
Post #565405 20th Sep 2016 4:19pm
Thumbs Up $W33T $0U7H3RN $UG4R
Post #565407 20th Sep 2016 4:28pm
Lew-M
Thanks Steve, top man Thumbs Up
Post #565408 20th Sep 2016 4:31pm
gilarion
Order some stainless steel fitting at the same time then its fit and forget, you will not regret it.
Buy from 4x4 Overlander a site sponser.
http://www.4x4overlander.com/product/nakat...ng-kit-ss/
http://www.4x4overlander.com/product/defen...ainless-2/
http://www.4x4overlander.com/product/defen...-coated-2/ For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #565409 20th Sep 2016 4:43pm
