![]() | Home > Td5 > New Td5 owner needs help |
Bjornxxx Member Since: 04 Sep 2016 Location: Sverige Posts: 18 ![]() ![]() ![]() |
Ok everybody, now I need your help! I finally dared to take apart the engine myself to change the washers, since no workshop around here wanted to touched it. All is dismantled and pretty easy actually. One injector especially looked extra dirty, and small amounts of soot has gotten past the gasket and up the injector.
What i need help with is: How do I clean the tip of the injector? Not the actual tip as i understand i shouldnt mess with this, but the part below the copper gasket. How do i clean inside the head? There are some dirt down where the copper gasket sits. I dont want this to fall into the cylinder. Just hope she starts and all is OK when Im done! Need to order the oilfilter also since I only got the centrifugal one. |
this is good link for injector seal replacement
![]() http://www.discovery2.co.uk/Injector%20Seals.html |
Hi all,
So tonight I put it all back together. Was a little bit worried that this wouldnt be it, since the washers didnt look too bad. Also worried when setting the injector height, because when i turned the engine over it sounded like something was leakingz Did the purge cycle two times, foot to the floor, cranking 30 sexs, nothing. Cranked again and it started with the biggest cloud of smoke ever to come out of her! Shut her off, and tried again. Started immidiately like she didnt do for weeks. Idle is perfect too. Now I want to use her for a week before I can trust this was it, but most likely it was. The fix was not hard at all, and my knowledge goes to changing oil, perhaps brake pads! Now next week oil change and all filters. Then I think I will treat her with EGR blanking and de-cat after MOT this fall. Also think I found the strange noise from the engine, a plastic bit, the cover for where the cables in the injectorloom connects, was loose inside! Thanks all for your assist! |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
