Home > Td5 > Td5 stuttering
smurf500
England 2005 Defender 90 Td5 HT Belize Green
Td5 stuttering
Has anybody come across this yet.i have defender td5 55 plate.when the rain is torrential like it was yesterday on the m40. The car starts to stutter.never dies.the first time it did it I thought it was fuel so changed the fuel filter. It only ever does it in heavy rain
Post #559574 28th Aug 2016 5:53pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Could be sucking water in side vent or down snorkel of you have one?
Check to see if air filter is wet?
Could also be a leak in air filter box 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #559580 28th Aug 2016 6:10pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I'd check over the electrical connections and wires through the bulkhead and under the drivers seat to see if any are worn or open to the elements. water and electricity don't work together 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #559915 30th Aug 2016 8:47am
smurf500
cheers pj.you were on the right track with that.the air filter was sodden
Post #561860 6th Sep 2016 1:58pm
Lou Sparts
There is a dump valve at the lowest point of the inlet ducting that should let water drain out this may have become blocked
Number nine in the picture above. 2005 Td5 90 XS
Steve
Post #561934 6th Sep 2016 6:17pm
dorsetsmith
as a point, also the air filter box has drain hole too
Post #561938 6th Sep 2016 6:24pm
4RF RDS
Also if you have a Safari style air intake top, turn it around. The "ram" effect is non-existant for a diesel.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #562136 7th Sep 2016 12:21pm
