![]() | Home > Off Topic > worst car you have ever driven .... |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
I occasionally drive a car that is slow, noisy, uncomfortable, leaks a bit of water in.......oops that will be my Series 1 then
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
Vauxhall Vectra 1.6 about M or N reg (I think,) bought as a temporary runaround about 15 years ago.
Absolutely hateful thing, it used to go and stop and go round corners - eventually, but it was so vague, it felt like all the controls were connected by long rubber bands so there was no sort of feedback from anything. I hated it so much I kicked it every time I got out of it and never bothered to lock it. |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Similar experience with a JCB 3C with no brakes(and I mean no brakes!). Only way of stopping was to keep your speed down and drop the back legs and hope they didn't make too much mess of the roads. As for car, then it has to be an Austin Princess in ![]() |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Most boring, soul sucking, car labelled object - Toyota Camry (all of them)
Most hateful - Mitsubishi ASX Cheers, |
languedoc Member Since: 13 May 2016 Location: Edinburgh Posts: 283 ![]() ![]() ![]() |
i have too many bad car memories i think.
Fiat 500 hire car in Paris with auto box and stop start was terrifying in traffic. i found religion trying to drive it through junctions. Rolls Royce corniche 1971 that some genius had bolted the rear axle mounts to the floor pan instead of the chassis and without washers so a brief drive on the blind summits of the A68 dropped the bloody thing right off the car and held together by the shocks, that was pretty scary |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
Ditto ![]() Ricky I had to look that up, ![]() at least it looked good ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
VW Caddy van. Could have walked faster and was doing stupid RPM when you eventually got to 70. Needed a packet of neurofen for any journey over 20 miles. The only vehicle I've ever threatened to leave a job over. Would rather drive a maestro
^^ must be bad if a maestro was a good alternative
Loved my maestro van
I'd keep that to yourself if I were you
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
I drive a lot of hire cars for work, lots of really boring stuff these days, but there's nothing that seems truly bad. For me, the just replaced previous generation Astra was available as a 1.4 petrol and that really wasn't good in terms of the engine. It was the first car in many years that felt really under powered, needing to shift down out of top at 60mph on a duel carriageway incline. 2007 110 TDCi Station Wagon XS
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 ![]() ![]() ![]() |
![]() Fiat Cinquecento , like this one. I borrowed it from a friend in Portsmouth and drove it home to Winchester M27 then M3 . Never got it over 50mph with lorries overtaking on a very wet day, a truly frightening experience. ![]() |
I had a Maestro once, wasn't too bad really despite being made from the front half of one and the back of another ![]() |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
BL called it the " quartic" wheel......it never really caught on, can't understand why. I started with nothing and still have most of it left! |
