Home > Puma (Tdci) > Are any cruise control kits truly plug and play? |
xtreme2252 Member Since: 15 Apr 2015 Location: Melbourne Posts: 29 |
This one claims to be Plug and play
http://www.ebay.com.au/itm/Cruise-Control-...SwA3dYMr7Q |
23rd Nov 2016 11:16pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
I read some where that for a few extra £ Mobile Centre can add the additional plugs if you don't feel confident soldering the wires.
For the speedo connection I hope this photo helps Click image to enlarge Cheers, Kyle. |
23rd Nov 2016 11:47pm |
jdci2001lu Member Since: 07 Oct 2016 Location: tonga Posts: 5 |
Hi Kyle,
How would the plug look like to fit into the connectpr , please? Or would soldering be better, I am afraid taking the wrong cable, Thanks in advance , Jean |
25th Nov 2016 8:00pm |
G'day Jean,
I recommend to solder the joint for a better long term solution. This is a copy from a reply I did for the same question on http://www.defender2.net/forum/post580274.html#580274 "From memory I removed the cover from the back of the plug. I did mine @18 months ago but it looks black in your picture. The wires will not fall out of thier respective positions when removed. The other method is to probe one of the wires and use a ohm meter to test for continuity to pin 13. You have a 1 in 3 chance of getting it right first time doing it this way." Cheers, Kyle. Cheers, Kyle. |
25th Nov 2016 10:19pm |
Thanks a lot Kyle ,
gonna try that out later today Jean |
26th Nov 2016 8:44am |
