Home > Camping, Caravanning and Holidays > Thule box on frontrunner roof rack
johnnyd
Hi All
Has anyone put a Thule luggage box on a front runner roof rack, i.e. are the slats in the roof rack a suitable size for the clamps to clamp around securely?
JD 2008 TDCi 2.4 XS CSW
Post #558052 22nd Aug 2016 4:35pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I don't know for definite as I haven't got a Thule box or a front runner rack. However, I do have a Hannibal rack and fit a roof box on there for camping trips. The only difference I can see is the slats run left to right on the front runner rather than front to back on the Hannibal. They look a similar width of around 100mm, so I would think the clamps supplied would not reach.
Also, most roof boxes are designed to slot over roof bars to reduce wind noise, and therefore will not sit flat on an expedition rack.
To solve this I made some oak bars which bolted to the rack with home made u bolts. I couldn't source online any square shaped u bolts the right size. I then recessed the brackets that came with the roof box into the oak. (Not the best description and I haven't got any pictures of this.)
The main difficulty was left to right positioning of the box due to my rack slats running front to rear. This might not be an issue with the front runner.
Hope this helps, and if I can take a picture tomorrow I will post it up 2002 110 td5
Post #558127 22nd Aug 2016 9:05pm
Jimb1978
It also whistled unbearably at first. Trapping a foam camping mat between the rack and the box solved that issue 2002 110 td5
Post #558129 22nd Aug 2016 9:08pm
Caterham
could you not simply ditch the U bolts / brackets and using 2 nuts / 2 washers / 2 bolts in each of the 4 fixing locations simply bolt the roof box to the roof rack slats. the slats will accept a certain size bolt so just go with that size. granted it wont be easy lining the nuts / bolt up but I'm sure it can't be too difficult?
good luck.
Post #558308 23rd Aug 2016 1:54pm
Jimb1978
That could work but you would only be able to get one fixing in each of the four locations due to the clamps pointing front to back on the roof box and still have to fill the gaps with a 50mm thick spacer. However, a penny washer to spread the load could replace the need for two bolts. 2002 110 td5
Post #558315 23rd Aug 2016 2:31pm
johnnyd
Now I'm looking at one of these 3 wolf box holdall type things, any comments?
http://www.4x4overlander.com/product/hanni...uble-copy/
Post #558333 23rd Aug 2016 4:01pm
Jimb1978
Yep, use those too. They are very difficult to load unless you can stand on your wing tops and bonnet if you load at the front or a drop down tailgate if you load at the back.
If you can access them they are brilliant though. Transfer to your tent and job done 2002 110 td5
Post #558345 23rd Aug 2016 4:54pm
johnnyd
Hmmm those boxes are too small, struggling here, what do people here use for storage on a roof rack, just normal holiday stuff, thats easy to secure ?
Post #559327 27th Aug 2016 2:09pm
Organic
United Kingdom 2012 Defender 90 Puma 2.2 SW Orkney Grey
Hello,
I've attached a Thule to our Flatdog roof rack using S.S. M8 bolts, the adaptor kit and 4x 25mm thick wooden blocks.The bolts are secured to the rack with nylock nuts and suitable washers.
The box is offset to accommodate our Oztent RV4 and accessories bag.
Post #559383 27th Aug 2016 7:41pm
DOOFER
i've got a full length front runner rack on my 90 with an ARB roof tent and three wolf boxes up front. one each for me, wife and daughter in an xl front runner bag. rule is, if you can't get it in your box, you can't take it.
we also have two more wolf boxes in the back of the 90, one for cooking and crockery and one for food.
this set up works perfectly for us and encourages us from bringing too much crap. DON'T PANIC
Post #559390 27th Aug 2016 8:03pm
johnnyd
Hi Organic, which adaptor kit did you use, there seem to be many, also is it easy to get any pics of the arrangement you made for the rack? Looks cool on top Very Happy
Post #559430 28th Aug 2016 6:19am
I'd say organic has the right idea, maybe pop down to b&q and buy a couple of lengths of steel or aluminium, put the under the rack and bolt thru from the roof box mountings ... Simple
Post #559436 28th Aug 2016 6:46am
Organic
JD
Hi Johnny,
My box is the Touring 200. Halford ordered the two adaptor kits in for me to compare that fitted. The only difference I could see was the U-bolt length and you're not going to be using them anyway! My main concern was obviously ensuring a rack slat was within the slot range of the box. The slots are quite long so had no problems. My receipt says I purchased the T-track Adaptor 697003.
I measured the distance between the box slots then secured the M8 bolts with a washer and nylock nut. I worked out the bolts needed to be 80mm long. I'll see if I can grab a photo later.
There is a gap between the rack slots and the actual bottom of the box which you'll need to pack. I looked at using rubber but it would have been way too expensive so I cut, drilled and painted wooden blocks.
Sorry, no pictures of assembly. I hope the above helps.
Paul.
Post #559442 28th Aug 2016 7:24am
Organic
I'm sure the frontrunner and flatdog racks are very similar. Here's an image showing my rack slats.
Post #559459 28th Aug 2016 8:09am
johnnyd
If anyone has any spare time, a diagram of what might be required would be fantastic, I will only have about 4 days to make this work before the trip to Scotland, At the moment I don't have the Thule box, I don't have the roof rack, I don't even have the Defender LoL as its with Zagato being treated, so it's all guesswork for me ATM.
Post #559536 28th Aug 2016 3:09pm
