Home > Td5 > interior light
yanto
Wales
interior light
Hi all
The interior light doesn't work when opening the doors. Replaced the switches and still nothing. It works by switching it on though?
Any help would be great.
Post #555967 14th Aug 2016 3:48pm
VeeTee
Netherlands
No, the lights are permanently live, but the ecu switches them to earth if the door is opened. Cheers, Vincent
MySite
Post #555976 14th Aug 2016 4:21pm
Clive
The interior lights are controlled by the 10AS alarm unit (ECU) which has inputs from all the door and bonnet pin switches to activate the alarm.
There are 2 or 3 different options for the way the interior lights work but it will need to be programmed with a suitable diagnostic tool, e.g.. Nanocom or similar.
Post #555977 14th Aug 2016 4:21pm
yanto
Wales
Thanks guys
I didn't think I had an alarm?
2003 defender 90 pick up
Post #555998 14th Aug 2016 5:57pm
VeeTee
Netherlands
That is line with you interior lights problem then... Think you had an alarm, but it (the AS10 unit) has been disconnected.
I have the same problem with the lights, because the previous owner installed an after market alarm and immobilser unit in stead of the AS10... Cheers, Vincent
MySite
Post #556001 14th Aug 2016 6:06pm
yanto
Wales
Any idea why it would be disconected?
Post #556002 14th Aug 2016 6:21pm
yanto
Wales
I don't even have an alarm fob?
Post #556003 14th Aug 2016 6:24pm
VeeTee
Netherlands
There were some problems with immobiliser unit (spider), mostly bad solder connections on the pcb board, but that was with the earlier models (300 tdi), but I guess that would have been solved by 2003.
Edit: If you don't have a fob, then clearly the alarm/immobiliser unit has been disactivated! Cheers, Vincent
MySite
Post #556005 14th Aug 2016 6:26pm
Clive
Easy enough to check and see, if you have one, the 10AS will be mounted on the bulkhead behind the speedo binnacle, either remove the binnacle (4 screws,) or the speaker below it and look up inside with a torch. The 10SAS is a green box about the size of a smartphone but a lot thicker with two multiway connectors on the underside.
Edited to add; what year vehicle is yours?
Post #556013 14th Aug 2016 6:57pm
yanto
Wales
2003 90 pick up. I should get an alarm /I mobilise
Post #556019 14th Aug 2016 7:13pm
yanto
Wales
Yep, just took the clocks out and can see the green box with a land rover sticker on it.
Can it be connected and can I get a fob? Or was it disconected because it caused problems?
Post #556027 14th Aug 2016 7:29pm
VeeTee
Netherlands
I guess the latter... Sad Confused Cheers, Vincent
MySite
Post #556031 14th Aug 2016 7:35pm
yanto
Wales
Recommendations for a good alarm then guys????
Thanks for all the comments.
Post #556033 14th Aug 2016 7:40pm
Clive
I don't believe the 10AS is generally too unreliable and you could get a fob, problem then is you will still need a diagnostic device in order to pair the fob with the unit, (assuming it does actually work.) It could just be that the original fobs have been lost or broken and the immobilised disabled.
Incidentally the 10AS can also control the central locking if you have it, although being a truck cab I suspect not, in that case a couple of parts will be missing but they can be added later.
Post #556037 14th Aug 2016 7:52pm
yanto
Wales
Cheers Clive.
Post #556087 14th Aug 2016 9:38pm
