Home > Puma (Tdci) > 2.4 gearbox oil level |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
[quote="X4SKP"]Over filling can be as bad as under filling or running on low oil, having lost (leaked) its correct quantity.
Drain Plug to Fill Plug = Correct Quantity The simple approach of removing the fill plug first (so you know you can refill it... ) then removing the drain plug...and then filling up to the fill plug is a fairly full proof method and its a shame the Puma MT82 Gearbox doesn't follow this long established 'general' approach... Too much oil can lead to excessive pressures within a gearbox, with overheating problems. quote] those that have had too much oil in the gearbox - once corrected did you notice any difference? |
27th Apr 2017 7:38pm |
