Home > Maintenance & Modifications > 2.4 Turbo Problems |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
must be a underlying issue for it to go boom...
call alive up tomorrow they sorted my poorly turbo issues.. |
7th Aug 2016 2:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20523 |
I'd say as above and probably electronic.
I'd recommend Alive too, Gary really does know his turbo's! You definitely shouldn't be having any issue at all as quick as that. |
7th Aug 2016 4:28pm |
EGT to high, overfuelling (any signs of excessive black smoke) or a turbo oil feed issue. If it was the gasket or manifold you would hear a chuffing from the exhaust gases escaping and you would smell the exhaust fumes in the cab. Cure for that is either fit a copper gasket or the better solution is to get the manifold seat and turbo face skimmed.
7th Aug 2016 6:44pm |
