Home > My Defender > PLEASE HELP FIND THIS 3.9 V8! |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
if its MOTd it will show on the government web site which it is and it shows it as Taxed as well so it is still about somewhere
Check the MOT history of a vehicle Registration number: J193CUU Vehicle makeLAND ROVER Vehicle model90 DEFENDER Date first used1 August 1991 Fuel typePetrol ColourGreen MOT history of this vehicle Test date23 October 2015 Expiry date22 October 2016 Test ResultPass Odometer reading84,769 miles MOT test number8075 1520 6165 Test date20 June 2014 Expiry date19 June 2015 Test ResultPass Odometer reading84,460 miles MOT test number6956 4147 4138 Advisory notice item(s) Nearside Rear Vehicle structure has slight corrosion (6.1.B.2) Offside Rear Vehicle structure has slight corrosion (6.1.B.2) Offside Front Headlamp deteriorated but light output not reduced (1.7.5a) Test date20 June 2014 Test ResultFail Odometer reading84,460 miles MOT test number4591 5147 4192 Reason(s) for failure Nearside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2) Offside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2) Advisory notice item(s) Nearside Rear Vehicle structure has slight corrosion (6.1.B.2) Offside Rear Vehicle structure has slight corrosion (6.1.B.2) Offside Front Headlamp deteriorated but light output not reduced (1.7.5a) Test date26 March 2014 Test ResultFail Odometer reading84,460 miles MOT test number1375 6508 4025 Reason(s) for failure Nearside Front Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a) Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2) Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2) Hazard warning switch faulty (1.4.B.1d) Nearside Rear Registration plate lamp not working (1.1.C.1d) Exhaust emissions carbon monoxide content excessive (7.3.B.1a) Offside Front coil spring broken (2.4.C.1a) Offside Rear Mechanical brake component has restricted free movement (3.5.1k) Advisory notice item(s) Nearside Rear Vehicle structure has slight corrosion (6.1.B.2) Test date9 July 2009 Expiry date9 July 2010 Test ResultPass Odometer reading83,295 miles MOT test number8727 2019 9120 Test date10 July 2008 Expiry date9 July 2009 Test ResultPass Odometer reading78,688 miles MOT test number9924 9369 8188 Test date18 July 2007 Expiry date11 August 2008 Test ResultPass Odometer reading74,945 miles MOT test number4406 9989 7118 Test date17 July 2007 Test ResultFail Odometer reading74,945 miles MOT test number9010 4819 7157 Reason(s) for failure Exhaust emissions hydrocarbon content excessive (7.3.B.1b) Test date7 August 2006 Expiry date11 August 2007 Test ResultPass Odometer reading66,574 miles MOT test number3932 4991 6422 Test date29 July 2005 Expiry date11 August 2006 Test ResultPass Odometer reading61,449 miles MOT test number1523 6051 5239 DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
7th Aug 2016 8:26am |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 |
It isn't being driven much judging from the mileage between mots. HR064 Hampshire and Berkshire 4x4 Response
7th Aug 2016 9:14am |
td5jim Member Since: 07 Aug 2016 Location: Northamptonshire Posts: 5 |
Thanks chaps - no not driven much at all. I think it's in someones barn somewhere. We'd trace through bank account but historic accounts are only kept up to 7 years.
Short of applying through a V888 I thought I'd see if anyone had seen it on here. |
7th Aug 2016 9:36am |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 |
You can find out who did the mot test .
Make a note of the details below , Take them to your local mot tester and ask for a duplicate . The certificate will have the details of the mot garage . Contact them and see if they know the owner reg number - J193CUU chassis number - SALLDVBF7HA704026 mot test number - 8075 1520 6165 |
9th Aug 2016 10:18am |
Great tip thanks Grizz, will give it a go!
9th Aug 2016 10:31am |
I did it the other week to track the owner of a car that hit my new transporter T6 and drove off ..
9th Aug 2016 12:37pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
How did you pull the Chassis number? that's not on the MOT check is it? |
17th Aug 2016 10:22pm |
haha , I own a garage and have a chassis number look up that's provided by dvla .
18th Aug 2016 7:20am |
That's cheating!
18th Aug 2016 7:21am |
adbseries3 Member Since: 27 Apr 2016 Location: sussex Posts: 49 |
Can you use this to trace a garage that did an mot a few years back rather than just most recent? Am trying to trace my Landie history.
18th Aug 2016 9:44pm |
