Home > In Car Electronics > Split charge Q's
bear100
Split charge Q's
Hi.
I am now in the market for a split charge system, what battery's are recommended? And how were they mounted?
I don't have a winch or intended to have one, it will run an engel fridge, various lights (outside camping) charging sockets etc
What solenoid is best?
Where did you mount the battery monitor? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #553175 2nd Aug 2016 6:16pm
Hi bear
Have a chat with Tim at the mobile centre, he sells complete kits with batteries, cables, connectors etc
I fitted one in 2 evenings for a fellow defender2.net member, he's now in on vacation testing and enjoying it
You need a few tools and electrical awareness but it's really not rocket science
Pm me if you want any more info
Post #553192 2nd Aug 2016 7:12pm
StephenO
Yellow Tops get a good name but can be expensive. I bought one of these below for my Discovery 3's set up and these also get a good write up on the Disco3 forum. I'll be using mine for my fridge, lights and charging iPads etc
I used the Tmax split charge system but now have an uprated relay
https://www.tayna.co.uk/EXV70-Enduroline-L...P8727.html
This is the relay I replaced it with but you can buy full kits
http://www.12voltplanet.co.uk/12v-300a-hig...relay.html
Thumbs Up Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #553195 2nd Aug 2016 7:15pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I spoke to Tim at Mobile Centre when I was looking at options. Got some really good advice and based on what I needed Tim put together a kit for me with the 7610 relay:
https://www.mobilecentre.co.uk/index.php?m...4e4ee6ef4a
Once I'd worked out where to borrow some big crimping pliers from it took about a day to fit with no issues as the kit was very comprehensive.
Would probably be quicker at fitting this a second time around as a lot of time went into working out where to fit everything so that it was accessible going forwards.
Keith Keith
Post #553310 3rd Aug 2016 6:42am
Draper hammer crimped
Are about £20 ...
Post #553313 3rd Aug 2016 6:50am
Keith5
I ended up borrowing a set from a colleague like these:
https://www.amazon.co.uk/dp/B015ZIA146?psc=1
Made it easy to do the 35mm cables Keith
Post #553317 3rd Aug 2016 6:56am
Is what I use to monitor the batteries
Post #553456 3rd Aug 2016 4:50pm
bear100
bp man now that looks good! i have just purchased a double din, so the relocation panel has a spare circle hole which hopefully will fit the gauge!! 2023 Defender L663 V8
Post #553457 3rd Aug 2016 4:56pm
eBay delivered from oz Thumbs Up
Post #553475 3rd Aug 2016 6:10pm
