Home > Td5 > Can't believe the difference
yanto
Wales
Disconected the maf yesterday and what a difference. I thought my 90 was a tad sluggish so took the maf plug out and now it is so much more responsive. Looks like a new one is needed. Very Happy
Post #551482 26th Jul 2016 10:30pm
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Forgive ignorance, but does the maf do?
Post #551524 27th Jul 2016 8:19am
Martin
Site Admin
Measures the flow of air into the engine  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #551535 27th Jul 2016 9:20am
Darcy Fairfax
Cheers, Martin.
Post #551565 27th Jul 2016 11:02am
lightning
It'll be even better with a new one, as without the MAF unit connected it runs in default settings.
Post #551681 27th Jul 2016 6:01pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I did exactly the same thing after reading the other thread (Lund's thread I think) and I found exactly the same thing, I was driving along and my 90 started doing it's usual sluggish cycle (Varies from day to day) I pulled into the next layby and unplugged the MAF and WOW!! Shocked I remember what it used to drive like when I bought it, amazing transformation, so like yourself, I will be shopping for a new one Thumbs Up
I also done the de-cat mod and I don't know how much of a difference that made but the turbo appears to kick in sooner and I can hear the whistle very nicely now, I might remove the center box as well, anyone done this? noisey, mot fail? Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #552036 28th Jul 2016 11:12pm
lightning
Mine was a bit quicker to respond with the CAT removed, but there was a drone between 65-70mph.
With the centre box removed it was indeed pretty loud (110 TD5 CSW) and l ended up putting it back to standard.
However some like the sound, best bet is to try it and see what you think. It's the only way you'll really know.
Post #552501 30th Jul 2016 10:10pm
miker
Mine is early enough to have no cats, and I recently removed the centre box. Really happy with the difference! Not too loud from inside. It does get a little drony under load at speed, but that's really only when going up long hills on the motorway. I like the noise regardless!
Apparently really quite loud from the outside, and plenty of turbo whistle!
I think it spools up more quickly, and drives more nicely because of it. That centre silencer is also damn heavy, so it's obviously made it faster!
Be warned that the centre box flange to the rear section may be very rusty. Took me a lot of careful grinding work to remove the studs without damaging what was left of the flange on the rear section. Also, the original centre had studs, the new one I bought only had a flange with holes, so I had to dig around the drawers for some bolts of the correct size!
Post #552514 30th Jul 2016 11:15pm
taffrican
Mike, where did you get the replacement pipe for the center box? Optimists say the glass is half full..
Post #552633 31st Jul 2016 4:36pm
miker
My local land rover bunch, dingocroft. I believe it is a Bosal part in stainless. Cost around £60+ vat?
Post #552726 31st Jul 2016 10:12pm
taffrican
cheers Thumbs Up Optimists say the glass is half full..
Post #552748 1st Aug 2016 1:06am
yanto
Wales
Just an update on the MAF sensor. I bought a genuine one from my land rover dealer at the princely sum of £ 125 and when connected it goes back to being sluggish? ???? Any ideas why chaps?
Post #560015 30th Aug 2016 5:22pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Faulty new maf maybe? Not unheard of. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #560027 30th Aug 2016 5:45pm
yanto
Wales
Not sure how to explain that to land rover? They will probably want my landy in to see why and change a fortune?
Post #560032 30th Aug 2016 6:04pm
lightning
You could do with getting a diagnostic before doing any more.
Can you take it to an lndy who won't charge you so much?
Post #560055 30th Aug 2016 7:25pm
