Home > Puma (Tdci) > REVERSING IN HIGH RATIO IN MY 90
johnp1887
United Kingdom 2009 Defender 90 Puma 2.4 HT Tamar Blue
Hi , i'm struggling with trying to reverse smoothly (and slowly!!) in high ratio in my 2.4 puma defender. the revs increase to about 1100 with clutch pedal released, I find that I have to apply the brakes as i'm reversing.is there a high/low switch on this defender,, my local dealer says that there isn't one, but he's not too sure. just had a new clutch fitted and its doing my head in. much preferred my old 300 tdi!! Sad
forgot to mention that it does it in forward gears as well which is a pain in slow moving traffic
I tried disconnecting the clutch switch and the tickover is raised all the time to 1100 rpm, so I know that the clutch switch is ok
as soon as the vehicle moves forward the revs increase and the speedo works ok so I guess that the speed sender is ok as well Sad
Many thanks to everyone, I fitted a new switch (IGM100000) today and now everything is as it should be.
Post #550809 24th Jul 2016 10:52am
Reverse is a taller gear ratio slightly than 1st, just the way it is. You could always use reverse in low range instead.
Most likely better for tight manovering, especially with a load on.
Post #550811 24th Jul 2016 11:08am
Bluest
It sounds like it is activating the increased idle speed that you should only get in first/reverse low range. I can imagine that would be very tricky. Does it do the same in first? Unfortunately I have no suggestions on how to fix it, someone is sure to know though. Sounds like a switch somewhere to me.
Post #550816 24th Jul 2016 11:17am
Caterham
As above.
There is a 'switch' I presume mounted on the transfer box adjacent to the linkage that jacks the revs up in low range to assist with matching revs in 1st n reverse and assist in effectively reducing torq in the lowest gear ratios.
Sounds either like switch is broke / disconnected or badly adjusted such that it thinks it's in low range when it's not.
Good luck.
Post #550832 24th Jul 2016 12:15pm
johnp1887
Thanks for the info, there are 2 switches on the transfer box, one will be for the diff lock warning light and I assume the other will be the hi/lo switch, I had thought that one would be for the reverse lights, but I have been told that the reverse lamp switch is on the main 'box
thanks for the help
Post #550840 24th Jul 2016 12:58pm
Caterham
YEP on main box for reverse.
let us know how you get on. Thumbs Up
Post #550860 24th Jul 2016 2:09pm
Happyoldgit
I don't think there is anything wrong TBH, all my Puma's have been very much the same. Low range is your friend when maneuvering in reverse. Steve.
http://forums.lr4x4.com
Post #550926 24th Jul 2016 7:24pm
Caterham
Steve, I think we're talking increased revs in Hi range not Lo Wink
Post #550927 24th Jul 2016 7:26pm
Happyoldgit
Yes I know that. My point was that reversing [on tick over in high range] is often a bit speedy, hence my suggestion to use low range. In fact Land Rover used to recommend using low range for tricky reversing situations rather than slipping the clutch in high. Steve.
Post #550929 24th Jul 2016 7:38pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
I think you may need to compare it with another to give you a starting point.
My 2.2 (and to fair my 2.4 3 vehicles ago) spends at least 75% of its time towing and whenever I arrive home things are fairly tight. I only need low range for the final manouvring (Ifor lives beneath the cattle box with approx' 3 inch per side clearance). The rev increase is noticeable (idle-jack) in low range but never a problem in high range.
If you try another at least you'll have something to gauge it by.
Incidentally, are you getting mixed up with the "anti-stall"? If you allow it to settle down by reversing a decent distance with the clutch out does it calm down?
Post #550944 24th Jul 2016 8:11pm
Cupboard
Idle jack should only happen in low range, tickover in high range should be tickover and that's that.
Thing with low range is that whilst the gearbox knows it's in low, it doesn't know it's in first or reverse. The ECU guesses based on your speed. That can make the car seem a bit broken if you're waiting for something to happen in low neutral and it occasionally revs itself for no apparent reason.
Post #550946 24th Jul 2016 8:15pm
Caterham
Fare enough.......but even mine doesn't tick over at 1100rpm in Hi so I think the issue here is he's experiencing idle jack in Hi and finding it too quick?
Me thinks?
P.s. I'm off to check on my clatter Smile
Post #550964 24th Jul 2016 8:41pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I wasnīt sure when I first read this thread, but driving my 2.2 this morning, I noted that the governed idle stays at 800 rpm in first or reverse with the clutch engaged. The idle only going up to 1100 rpm in low range. There must be a mechanical switch somewhere on the box that passes the info onto the ECU/electronic throttle, and it is more than likely that this or the harness is faulty, or the plug has come loose. Might be a really easy fix, and a massive source of satisfaction, being able to solve the problem without getting a dealer or workshop involved Smile . I'd suggest a quick look underneath, with a torch Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #551056 25th Jul 2016 8:31am
Caterham
I believe it only goes up to 1100 rpm once it's registered some movement (IIRC).
Post #551058 25th Jul 2016 8:34am
Bluest
The revs go up on my 2.4 as soon as you start to lift the clutch in 1st/reverse low range, no movement needed.
Post #551145 25th Jul 2016 3:52pm
