![]() | Home > My Defender > I've just bought a right shed of a landrover |
handpainted110 Member Since: 22 Jul 2016 Location: Gravesend Posts: 15 ![]() ![]() |
just an update
![]() Click image to enlarge lucky really this has been looked after and treated with red oxide over the years ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10866 ![]() ![]() |
Thanks for the update
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Curious how much a workshop like that would cost to rent/month?
I pay 600 a month have
it goes through my electrical business that I have upstairs 😉 |
chassis with it's 3 coat of paint after anti rust solution, zink rich primer now the top coat
next to poly bush every thing and rebuild the axles with new diff bearings. 9 ![]() Click image to enlarge let the rebuilding start. |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 ![]() ![]() ![]() |
Fantastic job! I know this is a contentious point on this forum. But to be honest, after much experimentation I would advise against poly bushes if your vehicle is to be used on the normal road, to occasional off road use. For sure they outlast the rubber bush options, but they are hard and in my opinion, detract from the original road ride that characterised the 110. I have used both and would rather replace a rubber bush twice than a poly bush once unless I was in serious off-road competition.
MGCarr Member Since: 18 Nov 2016 Location: Lancashire Posts: 59 ![]() ![]() ![]() |
![]() Nice project though and great facilities, very jealous ![]() |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Doesn't look too bad, good luck with the project! 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 ![]() ![]() |
Another landy with the same wheels as mine! you want to get them changed mind, they are horrid! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
bogwert Member Since: 02 Sep 2016 Location: Dundee Posts: 194 ![]() ![]() ![]() |
![]() Click image to enlarge Update Axles back in with new suspension and bushes Chassis has a layer of dust as not been worked on for some time Now to start to install all new brake lines and fuel line tank etc Will keep updated Also just brought a 200tdi discover with mint engine running for cheap will be using this as my donar car ![]() Click image to enlarge |
Wow, great work!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Looking good. Keep the updates coming 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
BossHog Member Since: 28 Jun 2013 Location: Fylde Coast Posts: 185 ![]() ![]() |
Nice work
