Home > In Car Electronics > GPS Antenna
mse
GPS Antenna
Not for the defender, but you guys tend to know things!
I need a gps antenna I can mount underneath a plastic bumper...eg the stickey fixing is on top and it works under plastic
I've seen loads that can be placed under plastic, but all that are stuck on something, with a plastic dash above it.
I need to mount one for the motorhome and I think under the front bumper is the only real place. Mike
Post #549651 18th Jul 2016 10:24pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Why do you need to mount an external antenna for your GPS?
Mounting the GPS antenna low under the front bumper is going to give you all sorts of issues with lost satellites, interference from the engine electrics etc....
The rule for GPS antenna, and come to think of it, ALL antenna mounting is to get as high and clear as possible..
If you really want to mount one at the front, just pop a decent 3M sticky pad on top of the one you get, and use it that way... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #552962 1st Aug 2016 9:38pm
mse
Thanks - long done now Mike
Post #552964 1st Aug 2016 9:54pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
What was the solution...?
Simon
Post #552968 1st Aug 2016 10:21pm
