![]() | Home > V8 > SU carburettor breathers |
Iggle piggle Member Since: 10 Sep 2014 Location: Wales Posts: 378 ![]() ![]() ![]() |
Looking at your picture in "Lets see your V8" your breathers look to be correct, they go from the rocker cover through a flame trap & to the carb on the N/S & the same on the O/S but it also splits off & goes to the air cleaner
not sure if you mean the fuel vent pipes though? as yours look to be joined & then go toward the air cleaner? |
http://new.lrcat.com/#!/1228/13789/18670/1466/19008
![]() Click image to enlarge item 10,11,12 orange arrow flame trap grankgase breather yellow arrow |
have look at this
![]() http://forum.lro.com/viewtopic.php?f=21&t=46743 number 1 is wrong this the fuel feed to the float chamber from the tank |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 ![]() ![]() ![]() |
Yes those are the ones, Where do they go on your v8? 1999 Land Rover Defender 110 td5 station wagon 1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
mine are the same as your signature picture at the top of this thread,
both pipes are routed across the engine to the N/S inner wing & clip on to the outside of the chassis from memory they are fuel vent pipes in case the floats stick etc & for that reason you don't want them to near your exhaust!! mine were actually melted to the down pipe when i bought it! ![]() ![]() |
thanks, will have to sort mine out then.
Melted to it? That isn't what you want should they have fuel passing through them ![]() 1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
