Home > Puma (Tdci) > Ashcroft's MT82 Output shaft kit "leakage"
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
http://www.ashcroft-transmissions.co.uk/mt...t-kit.html
Well after plenty of reading, I've finally decided to fit the above mentioned kit.
I do, however, have a quick question for those in the know or who have fitted one. As this solution allows oil to "leak" from the gearbox to lubricate the splines, I was wondering if you would need to add a little extra oil to the gearbox to compensate for the leakage. From memory the gearbox only takes 2.2ltrs, I already have some BOT328 oil left over from when I changed it at 80,000k's. I don't want to overfill the gearbox, as that can cause other issues, but was interested in your thoughts in regards to if and by how much you might have to top it up.
Post #548070 12th Jul 2016 10:34am
Cupboard
In 10k miles mine hasn't leaked enough to be noticeable.
Post #548106 12th Jul 2016 11:55am
driver9
Instructions on how to fit the output shaft are in the August 2016 edition of Land Rover Owner International. Does not say how much oil they used but you could ask Ashcroft what they recommend.
Post #548148 12th Jul 2016 2:45pm
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
I asked Ashcrofts this when mine was fitted and he said it was only a few ml worth of oil so it is negligable, just fill with the normal amount Thumbs Up
Post #548195 12th Jul 2016 5:33pm
jst
likewise to ^^ just fill normal amount Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #548311 12th Jul 2016 9:14pm
ozy013
No worries, thanks for that. Just wasn't sure.
Hopefully my LRO International turns up soon, always a bit of a delay in these neck of the woods.
Post #548382 13th Jul 2016 7:16am
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi all! I just ordered my ashcroft mt82 output shaft kit. When replacing the old one unit I think it's better to change the Oring plastic seal no? Has someone the LR ref of this part? Because I think it doesn't come in the ashcroft kit.
Best regards
Post #572647 22nd Oct 2016 12:23pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Well pleased with my Ashcroft shaft Thumbs Up
Post #572762 23rd Oct 2016 6:58am
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Best regards
If you mean item 20 shown below, you do not need it (or item 21) with the Ashcroft kit - the additional part in the Ashcroft kit has seals built in (early ones used a conventional oil seal, the later ones use two o-rings). May be a good idea to replace the gearbox output oil seal (item 4) and the transfer box input oil seal.
Post #572771 23rd Oct 2016 7:54am
Okan
Hi thanks for the advise. The o-ring I was telling about is the item 4. Do you have the LR ref part of this o-ring pkease? And maybe the LR ref part of the transfer box input oil seal too?
Best regards
Post #572776 23rd Oct 2016 8:22am
Fifth Horseman
Gearbox output oil seal (item 4): LR0058800
Transfer box input shaft oil seal: IVC100000
Post #572811 23rd Oct 2016 1:06pm
Okan
Thanks for answer! About the transfer box input shaft oil seal... is it not a LR ref part?
Regards
Post #573157 24th Oct 2016 4:36pm
Fifth Horseman
Yes it is a L/R part, there are many part number prefixes other than LR (RTC, MWC, VHY, FTC and others)
Post #573158 24th Oct 2016 4:44pm
Okan
Ok
I understand! With this do you know the ref of the front and rear axle oil seal plastic O-ring? This one where are connected the front and rear propshaft. I don't know this part's name in english.
Regards
Post #573163 24th Oct 2016 5:21pm
Fifth Horseman
Front differential oil seal FTC5258
Rear differential oil seal FTC4851
Transfer box front and rear output shaft oil seal FTC4939
Post #573174 24th Oct 2016 6:39pm
