Home > Technical > Planning a new project |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
We are all mad.
Now that that's cleared up, Welshsurferdude is selling one. |
7th Jul 2016 9:37pm |
If you're going to build one, go for option b. The SVX hood just looks like an old fashioned SilverCross
Knowing what I know now, after building the v8, I would just start with a new chassis! Saves a lot of hassle. |
7th Jul 2016 10:26pm |
Rogeo1983 Member Since: 18 Nov 2015 Location: Horsham Posts: 30 |
Hi Greeni,
Having spent all last night looking at photos of both, I can now kind of agree with you. So if I forget the svx model, and just go for the hoops and canvas. Now I still want to have a roll cage, external on the front, which will flow inside on the rear. I don't need the rear covered with a bar, but just want it attached to the back behind the cab. So here is a question. Can I have a frame that is external in the front, but goes inside through the hood behind the cab, and that if required I could put the truck cab back on for the winter months? I would still need the seat belts to be attached to the bar. Any ideas? I like the idea of these pictures Click image to enlarge Click image to enlarge |
8th Jul 2016 1:26pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7905 |
Might be of some interest:-
http://www.defender2.net/forum/topic46373.html James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
8th Jul 2016 7:12pm |
I just found a roll cage that will fit standard canvas hood, plus with removal of the seatbelt mounts on the frame, I could reinstall the truck cab if the cold got too bad!
It would just require a bolt on attachment for the seat belt mounts. I've emailed for a price...... That will probably hurt. So with the canvas and the door frame to buy it could be an expensive build. I'll have to weigh it up. I could just do a simple canvas conversion, but I would like the option to swap back, and I want a roll cage on the front for protection. Or if anyone knows where I can get the cage from this pic, great. Click image to enlarge |
8th Jul 2016 9:45pm |
Hi, that looks possibly like a Protection and Performance cage (PPcages). Though it looks like A Nene advert.
It's generally known as a NAS spec cage and hood. North American Spec. Have a look on Rovers North's website for parts listing. |
8th Jul 2016 10:30pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 808 |
Standard canvas military hood on a 110 here. Did most of the last two winters with the back rolled up! If it is too cold then you are to old/soft Seriously, there is a pretty beefy body mounted roll hoop with the military spec frame and this should cover most typical roadgoing situations as well as a normal hard top.
9th Jul 2016 11:33pm |
