Home > Technical > Switch to disable ABS |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
It might have been intended to turn the traction control off, because disabling the ABS also disables the TC.
Disabling the TC is a well documented addition. |
10th Jul 2016 8:15pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 407 |
Hey Dorsetsmith, Do you have a diagram like this for the traction/stability control? Thanks Yan |
22nd Jul 2016 9:04am |
contents list for diagram show no traction/stability control only ABS
22nd Jul 2016 9:39am |
What year is the diagram above from?
22nd Jul 2016 3:00pm |
08 2008
22nd Jul 2016 3:06pm |
Do you have 2015?
Can this mod even be done on later vehicle? I saw a post somewhere that said it was no longer possible? |
22nd Jul 2016 3:12pm |
the only one i fond is below
http://www.defender2.net/forum/topic46886.html |
22nd Jul 2016 3:24pm |
