![]() | Home > Puma (Tdci) > dash removal question before i break it! |
It's all part of the fascia. It's easier as well if you remove the radio first.
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
any special tools needed to extract the radio ?
Pom |
You can get the tool from halfords as its just two wire legs for about £6. I used a couple of pop rivets, did the job.
http://www.halfords.com/webapp/wcs/stores/...yId_165626 |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i've taken out the radio and the 2 torx screws and still found a fair bit of resistance, will it help pulling in a particulare direction rather than straight out, and how many clips and where are these clips located that are still holding it in?
p.s. sorry for jumping in ![]() |
http://www.defender2.net/forum/topic4502.h...lumination |
thanks lorry man, sometimes dyslexya and using the search function dont mix,
and no i'm not joking and yes i probably spelt it wrong, but who the hell comes up with a spelling like that ![]() |
Had that fascia panel off a couple of times to add bits and pieces. Was going to do a reply when I remembered about blackwolf's post. I'm a lazy sod, easier to copy and paste than to spend 5 mins explaining what someone else has already covered so well
thanks for the help. Did it!
Used a claw hammer on the top which did the trick. pom |
