Home > Technical > Back door lock |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2640 |
You can buy the later 2002-on variant with the attachment for central locking. Only problem is that it uses the later longer barrelled key, so you'd need to change that too.
Alternatively you can split the old lock (drill the rivets out) and attach a rod inside, or I've seen people attach it to the locking tab on the inside too. |
26th Jun 2016 7:54pm |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 |
Cheers retroanaconda. If I split the lock, how do I join it back together again?
Will the later locks go on to my door without me having to modify it? Cheers. 300tdi 90 1996. |
26th Jun 2016 10:20pm |
Some small countersunk screws/nuts can be used to re-tighten it. Beware of springs going boing if you open it though!
Yes the new style will fit, the rear door lock orifice is the same right from present day back to the Series 2 in the late fifties. |
27th Jun 2016 5:33am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
The repair kit I bought for mine the other week (locking spring breaks) came with pop rivets to hold it back together. Seems to work just fine!
27th Jun 2016 9:21am |
Hi miker, where did you get that kit from? 300tdi 90 1996.
27th Jun 2016 5:41pm |
eBay! About a fiver,
defender safari door lock repair kit. |
27th Jun 2016 6:15pm |
27th Jun 2016 10:50pm |
termohe Member Since: 23 Jul 2012 Location: De Pinte Posts: 15 |
Door lock with central locking FUB500060,
2nd Jul 2016 11:28am |
