DRW58
I'm pretty sure my problem will be a bad earth, when the trailers connected the right hand indicator has all the indicators flashing, i.e. All on the Landrover all on the trailer, plus a side light.
When I press the brake I get the left indicator dim too!
I checked the connectivity on the lower section of the loom using a multimeter and got a good response on all the wires but one, and this is where I've come unstuck. On one wire I didn't get a buzz but got a number 344 on the display? Can any one advise what this means?
Is there any way to test the circuit above the connector in the rear wheel arch?
Dave I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and all's where it should be!!!! Ho hum
23rd Jun 2016 8:37pm |
