Home > Technical > Large crossmember bolts
Defcon1
United Kingdom 2005 Defender 90 2.5 TD CSW Chawton White
Can anyone give me the sizes of these bolts, please?
Friends with Defender 90's cannot identify them.
Post #537254 3rd Jun 2016 4:10pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
M10x110mm - part no. AYG100250
Post #537259 3rd Jun 2016 4:39pm
dorsetsmith
what do they bolt on crossmenber on a 90
don't bother seat belt bar parts Thumbs Up
Post #537260 3rd Jun 2016 4:45pm
Rear seat belt anchor bracket.
Post #537262 3rd Jun 2016 4:52pm
dorsetsmith
Thumbs Up
Post #537265 3rd Jun 2016 4:57pm
Defcon1
Thank you for the replies. Thumbs Up
No wonder my friends could not identify them, they don't have seats.
Post #537287 3rd Jun 2016 6:42pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Can you use these to bolt rear corner protection bumperettes to the rear cross member?
Post #537345 3rd Jun 2016 9:41pm
mcgiver
Australia
just fitted masai swingaway carrier to crossmember at this position..to prevent panel damage spacer needed to be fitted between x- member and lower pivot of carrier which meant the new 110mm bolt was too short. you may find the same problem if fitting step/bumperette ...120/130mm bolt will solve this with the final 40mm or so threaded .....hope this helps..
Post #537442 4th Jun 2016 10:59am
nitram17
careful....if its too long you wont be able to fit the bolt into some of the bumpettes such as ths safari ones as the rear face prevents placing the bolt.
Post #537445 4th Jun 2016 11:17am
mcgiver
Australia
ahh... didn't see that problem...also noticed my rear panel sits out a little more than on the blue defender pictured....the big hammer must have been misplaced when mine was built....
Post #537455 4th Jun 2016 11:38am
