Home > Puma (Tdci) > Chirp whoop noise from air inlet.
GuyT
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Indus Silver
Hi All
I have a problem I think, the dealers at first said they hadnt come across it before, took the car out and drove it till they heard it. They then latter took out a vehicle of same spec and year to see if it did the same, apparently they think it did.
They have check all the pipework and checked for anything obvious on the acle etc, and all is normal.
Anyway its a 2014 2.2 Defender 90
The problem is a chirp or whoop noise which I can hear, with window down, which seems to come from the air inlet.
It happens when accelerating gently in second and third, the noise is above normal inlet rumble and is over in a split second. Sometimes there is a hesitation directly after it. This noise is intermitent.
Anyone come across this, I would be grateful for your thoughts
GUY
Post #536977 2nd Jun 2016 5:59pm
GuyT
Still doing it Rolling Eyes
Starting to anoy/worry me.
No one come across this before?
Thanks
GUY
Post #538947 9th Jun 2016 9:08pm
Chimbwe
My 15 MY made an annoying noise from air intake when I collected it. I took it back and was told they all sound like that now! I did test drive another one and yes it had similar noise. I never found a problem but fitting a safari snorkel has certainly masked it (as long as the vent is pointing forwards!).
Post #539248 10th Jun 2016 8:50pm
GuyT
Thanks for your reply.
I really cant see this as a normal sound.
Another issue which could be related is my oil service led in the square unit, has come on.
The vehicle has only done 1800 miles since last oil change.
Its at the dealers Monday so will see what happens.
If it is a case of they all do it, I will need convincing as to what is actually happening.
Guy
Post #539279 10th Jun 2016 10:03pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Maybe you get a recording or video up? or see if anyone local can give you a second opinion? It isn't always easy to describe sounds to others. Better to hear it first hand. Thumbs Up
Post #539283 10th Jun 2016 10:12pm
GuyT
Yeah I have a go pro recording of it, which I showed to the dealer so they knew what to listen for when they took it out.
Its a massive file, am going to see if I can get it edited down to a few seconds where the noise happens,
Not having much luck at doing this will ask one of my children see if they can help.
Guy
Good idea second opinion, will do that
Post #539286 10th Jun 2016 10:21pm
apt100
Just noticed your location. I suppose that might limit the number of local members.
Post #539287 10th Jun 2016 10:23pm
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
From your description I think I have the same noise. 2015 90, and has done it for all of its 28'000 miles, although intermittent, and only under similar conditions to as you describe. I havent worried about it because I find it quite a satisfying noise!
Post #539295 10th Jun 2016 10:56pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
My 2012er makes that noise, and always has done. It only occurs rarely, in low to mid throttle and load situations, and sounds to me like the turbo hiccuping on a movement of the throttle. I find it quite sweet and amusing. With the aluminium snorkel it is amplified and and brought up close to the cabin.
I wouldnīt worry about it. Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #539305 11th Jun 2016 5:01am
GuyT
Thank you all for your replys. Reasuring in a way that others do it.
Shes in the dealers tomorrow to check out the oil service light after 1800 miles in six weeks since last oil change.
See what happens.
Guy
Post #539671 12th Jun 2016 5:32pm
dudley472
United Kingdom 2009 Defender 90 Puma 2.4 HT Keswick Green
yes, mine does it too, 2014 90, glad i'm not alone
Post #539859 13th Jun 2016 2:49pm
GuyT
Car back from dealers today.
They seem to think the oil service light hadnt been reset properly, anyway they carried out an oil and filter change FOC.
With regard to the chirp/ woop noise, they checked for fault codes, there wrre none and checked all pipework for leaks, no leaks.
So guess thats normal then, will see if anything further develops.
I have to say I do get excellent servicec from my local Dealers.
Thanks again all for your thoughts and comments
GUY
Post #540180 14th Jun 2016 7:44pm
