Home > Technical > Cold Air In Footwell |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
Mine has a useful chiller compartment below the driver's seat - the faster you go, the worse it gets Short of a major sealing exercise in the cubby with the various electrical bits and pieces in it, I couldn't see a way of stopping it. I can't feel any really bad drafts from the footwell itself 1953 80
1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
8th Dec 2010 2:56pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
DM, you could have a hole in ya sock,have a check 2.4 90 XS
8th Dec 2010 3:36pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
8th Dec 2010 4:07pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
In the 110, with the heaters on you channel a real cold draft through to the rear passengers. In fact, it makes its way up between the cubby and drivers seat and chills my side.
Someone could base their entire final year aerodynamics project on the movement of heat around a Defender One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
8th Dec 2010 9:37pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
In my LHD 90 the air blows on the passenger feet (right side).
It disengages when I set the air-blow to 1. Janusz www.yahodeville.com |
9th Dec 2010 7:28am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I was out the night before last testing Pete’s EGR closure thingy and I could not believe the draft that was coming between the seats and the cubby box on both sides. Where the hell does it come from, it’s not just a draft it’s a bloody gale!! My wife made a similar comment the other day and being slightly on the defensive I replied that “it’s a Defender”. That got me nowhere as all I got was a smug “well mine doesn’t do it” referring to her tdi 90.
9th Dec 2010 9:00am |
Does the 90tdi has a bulkhead behind the seats and your Puma not maybe? Roel
9th Dec 2010 1:34pm |
Exactly what I said to her But of course by that time she had moved onto another subject |
9th Dec 2010 2:45pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
Ive not noticed the draft.
I bet your problem is poor assembly eg the pannel gap foam isnt correctly fitted...its not a hard job to check, but i would suggest it takes a few hours and one for the summer. As your there - you would probably want spare or sealant!! Mike |
9th Dec 2010 5:09pm |
Maybe - mine's fairly heavily coated with waxoyl, though.
I just assumed that it was an airflow consequence of the heater positioning channeling the cold air. To be honest, it's fine for me in the front (I have access to plenty of heating) it's more the kids in the back that I'm thinking of. I'll just have to wait for Dgardel to fit his Wabasto One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
9th Dec 2010 11:39pm |
