![]() | Home > My Defender > 1989 Ninety CSW - Update: 8 cylinders |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10940 ![]() ![]() |
+1
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Brave man, top job
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 515 ![]() ![]() ![]() |
Thanks guys! Just hope it doesn't leak now next time it rains!
![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Bit of an update:
Engine has needed some work recently. The head gasket went a few months ago so it was a good excuse to dismantle bits of the engine. The Haynes manual was invaluable and made it a relatively simple job. I just took my time and went through step-by-step. ![]() Click image to enlarge The head was slightly marked so we sent it off to be skimmed. When we got it back I gave it a good rub down and then reassembled the valves all with new seals. ![]() Click image to enlarge Then the head went back on, valve clearances adjusted and finally put the rocker cover back on. With a little gentle coaxing, she started! ![]() Shortly after the head gasket went, we went on a greenlaning day in the Dales with Russ Dykes from Yorkshire 4x4 (unfortunately I wasn't allowed to drive ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge At some point during the day the we must have banged the exhaust on a rock as it began vibrating against the chassis. Bending it back with a crowbar was relatively simple. Recently, it's taken about 10 seconds of turning the engine over to get it going after it's been stood a day or so. A bit of research suggests the fuel lift pump may have gone, so today's job was to fit a new one. A fairly simple one, although it's worth whipping the injector pipes off to get better access on the 2 bolts holding it in. Old one out, new one in: ![]() Click image to enlarge Not had chance yet to see if it's fixed the problem. I have also replaced my tired old door hinges. Managed to get my hands on a set of take-offs from a puma which was having optimill hinges fitted. They were in Santorini black so I rubbed them down and very crudely sprayed them arles blue. It was the first time I'd used the spray gun attachment for the compressor so the finish is a bit rough. The old bolts and cage nuts were in a shocking state so new cage nuts and stainless steel bolts all round and plenty of copperslip. After a lot of fiddling, the new hinges were on and the door alignment is much better. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Looks good and surprisingly similar to mine with very similar problems!
Good find on the door hinges. I might try that tactic as mine are shot too. I'm interested in the fixed rear windows. Do you think your are a factory fit? Mine has fixed windows too but I can't tell if they've been made to fit a hole that would have had sliding windows in or it was built like that. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
My old fixed windows were definitely not factory fit, they were actually fitted quite poorly: Apart from them obviously not being the right size, they also had rough edges and a loose rubber seal. As SailingTom said, mine was a hardtop and had been converted at some point. The alpine windows were also cut out presumably at the same time as the windows but whoever did it, didn't cut them in the usual place just above the gutter, instead they are a bit higher.
I believe some station wagons were fitted with fixed windows from the factory but I liked the idea of sliding windows mainly from our dog. I could get some measurements in the morning if it helps. ![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Blanc Member Since: 14 Jul 2016 Location: Suffolk Posts: 43 ![]() |
May I ask where you got the stainless hinge bolts with the correct size heads?
Thanks David |
David - I got them in a kit a bit like this one: http://www.ebay.co.uk/itm/321911504951 Matt.
Ah, s'ok thanks. Mine are in a frame much like sliding ones. Interesting that they might be 'factory' though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
My old ones weren't in any sort of frame, they seemed to just be a generic sheet of glass cut to window shape. Masai sell these fixed windows, do yours look anything like this: http://www.masai4x4.com/defender/side-slid...y=18520778 Matt.
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Great work
Makes me want to go & buy a G reg 90 ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Made a few changes in the last few months:
Firstly, a nice shiny steering guard from Paddocks: ![]() Click image to enlarge Also fitted my Kenwood Active Sub on the back of the cubby box. Sounds incredible, not just the bass, but seems to make the music somehow more audible. When I just had the 4 speakers the sound just got drowned out by the engine. I can't seem to find the pictures I took however... Then I replaced the leaky leak-off pipes and did a full service. Glad to see the oil was free of sludge/grime etc. Fuel filter was a pain to get off because of its placement in the engine bay which is non-standard due to the Disco 300tdi conversion. New leak-offs: ![]() Click image to enlarge Awful fuel filter location: ![]() Click image to enlarge I'd been having some cooling woes recently, or at least, so I thought. On a short 5 mile journey into town, the temp gauge was reading well into and over 100C. When we pulled over, I got an IR thermometer on the thermostat housing and I couldn't get it to read more than 80 odd degrees, also the rad didn't feel abnormally warm either. The only potential symptom of over heating is the expansion tank leaking. I replaced the expansion tank: ![]() Click image to enlarge Secondly I replaced the water temperature sender with the Defender one (black ring) to match my defender temp gauge. ![]() Click image to enlarge I haven't yet had chance to test the gauge but I'm hopeful it will now read a normal temperature as I'm coming to think I never had an overheating problem in the first place. On the subject of gauges, I decided to replace the clock with a rev counter. Very easy installation, just ran a cable from the W terminal on my alternator. I would have rather had a more factory fit looking dial but the genuine one was way over £300. However, it is nice to know the revs. ![]() Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Bit more progress this evening. Nice heavy package arrived in the post - some sound deadening!
![]() Bought 30 sheets, wasn't quite enough to cover front seating area, got the transmission tunnel done which was the priority area. Also got the footwells done, but still have the seat boxes and under-cubby area to do. Hopefully this will help reduce the transmission whine. ![]() Click image to enlarge ![]() Click image to enlarge Also got a bit of rubber checker plate matting for a bootliner: ![]() Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Looking good
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
