Home > In Car Electronics > Just fitted auxiliary power sockets behind the cubby-box
flyingfab
France 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
Hello Very Happy
I recently decided that I needed a few auxiliary power sockets in the back of my Defender. The goal was to have two USB, one 12v socket, plus a free 12v wiring left for later. Everything was to be connected on a permanent positive feed, via illuminated switches when on.
I first bought a "mini-pod" from Mudstuff, originally supposed to be used to fit extra gauges onto a pre-2007 dashboard. I then used a Dremel to make the openings. It is better to have a tiny play in the switches openings, in order to allow the switches' axis to move freely
I chose to make the wiring and to fit it into the car only once finished, instead of working gradually in the car. So, I took the measurements using an old cable with some adhesive tape to hold it and marked the key areas with a pencil onto it.
The connectors. Each cable (1,5mm˛) is marked. I used a cable tie to prevent from tearing out. Massive use of heat shrink sleeving (which works very well with a good hairdryer)
I installed a fusebox (Mudstuff again) onto the extra threaded hole located on the battery terminal, using a short M8 bolt (must be maximum 10mm long to fit properly). The maximum amperage for the wiring and sockets is 16A but I preferred to stay on the safe side by using 10A fuses.
A few adhesive cable clips to hold the wiring in place. It then passes through the hole located beneath the left hand side seat, since I didn't want to make any drilling. I just removed the factory cap and used instead a seatbox grommet ref.269257 (thanks to dorsetsmith for the part reference Wink )
I connected the earth to one of the two bulkhead lip bolts located just behind the left hand seat. (thank to custom90steve for the tip Wink ) I tested them with a multimeter before and after, and it appears that the earth is excellent here. But, surprisingly, it is really poor on the other bolts ...
The wiring splits here ; the positive cables run to the battery, while the negative ones are connected to a big single insulated terminal.
Although handy, using a single connector for three wires is not really conventional. So I used several terminals with an old cable to test the reliability of such a connection first. Crimping is a bit tricky but, once you know how to place the cables, this works very well and the connection is perfect.
Here it is ! Now I can plug my iPhone, iPad, iWhatever ... and a fridge for Mrs Flyingfab Mr. Green
Post #535769 30th May 2016 1:06am
adbseries3
England 1999 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Very professional job.
Post #535787 30th May 2016 8:20am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Very neat indeed. Top job TD5 Defender 90
Discovery 3 HSE
Post #535789 30th May 2016 8:29am
flyingfab
Thanks Very Happy
Post #535939 30th May 2016 5:59pm
gilarion
Great how to do write up and a very professional looking job. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #535955 30th May 2016 6:32pm
