Home > In Car Electronics > Calling Switch Connector
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Ciao,
How do I get the connectors back out of the block;
I have used the wrong colour wire and need to remove the little pins from the block. I can see the little tab I need to press down to withdraw the pin but I can't seem to get it out to save my life.
Yan
Post #535593 29th May 2016 9:48am
Alien
Australia
A jeweller's narrow flat screw driver may do the job.
I've used an open split pin in the past with a little bit of grinding/filling to suit the width, squaring the end is important too.
Cheers, Kyle. Cheers,
Kyle.
Post #535594 29th May 2016 9:59am
