Home > Puma (Tdci) > Radiator Muffs |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1842 |
Morning All,
Can anyone tell me the pro's and con's of fitting a radiator muff like the exmoor one http://www.exmoortrim.co.uk/index.php/cata...k-pvc.html (Hope that link works ) Rosco 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
7th Dec 2010 9:12am |
Thanks for that Red-dot
I'll put that idea to bed then Cheers 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
7th Dec 2010 2:24pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
before you do that rosco, if you do a lot of offroad driving without high load (ie low speed, steep hills etc) in winter, a rad muff will help with overcoming the problem of a low engine temp and a low heater temp. as long as you keep the flap open a little it ll be fine. To put that into context, At the weekend i spent a lot of time idling in very cold conditions and the gauge went down so low that the heater just really wasn't doing much. A rad muff would have really helped that. Also helpful on very cold mornings, you keep the flap closed but then have to hop out and open it when the engine gets to temperature.
also v v useful if you do any wading. a few weeks ago in wales i went thorugh deep water which was full of grass and all kinds of crap. took me the best part of half a day to clear it all out of the radiator, and at the time I wished I had a rad muff to close. |
7th Dec 2010 3:14pm |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 |
In very cold weather (like now) I use an empty feed sack as a rad muff.Works fine on short journeys and helps with quick warm up .Keeps temp up when working at low revs off road.I have noticed no change in fuel consumption or any black smoke and no loss of power. Best of all its cheap. :D
7th Dec 2010 9:39pm |
BigMike/Toplink cheers for the additional advice.
Maybe I'll put it back on the Christmas list. The rad muff that is. Im fairly certain my better half wont give me an empty feed sack as a gift. Rosco 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
8th Dec 2010 8:49am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2047 |
A muff would be nicer
8th Dec 2010 8:59am |
