![]() | Home > Td5 > TD5 gearbox level plug issue |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
Hi Folks,
I have been going through my 2006 TD5 replacing all fluids and filters and have only the gearbox remaining to finish the job. The level plug however is totally knackered and I suspect will have to be removed at some time when the box is out of the vehicle. Can any one advise an interim solution? can I fill the gearbox once drained via the gear-stick end being careful about the amount I add? Advice appreciated as always John |
Thanks for the reply - will take a look shortly.
Quite happy as MOT passed without any issues apart from some weeping balls to look at!!! |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
I have the opposite problem. I can't get the lower one out. It's on my to do list when I do the seals.
Luckily mine leaks out so I just keep topping it up! 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3005 ![]() ![]() |
Most seem to have leaky balls. LR sell a "one shot" grease cartridge that you put into each side. Being grease it does not leak out so much. |
oil level plug R380
![]() Click image to enlarge oil drain plug with mag ![]() Click image to enlarge |
Thanks for the response lightning - will get hold of some grease and give it a shot when I order a new filler plug (cheers DorsetSmith).
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
Make sure you buy genuine, the Br*tpart filler plug will wind right through into the gearbox......
That would not be a good day!
Cheers guys genuine LR plugs now in my possession.
Got her with a friend next weekend with access to hydraulic lift to see if the stuck plug can be removed or not. |
MrWisty Member Since: 24 Mar 2016 Location: Shropshire Posts: 3 ![]() ![]() ![]() |
I've just had the same problem with the R380 filler plug. Using a T55 driver started to chew the plug up, so I gave the problem to my garage. They tried die-grinding the plug socket out to T60 but it still wouldn't move. Finally they welded a large nut onto a short length of 3/8th bar and then welded the other end of the bar onto the filler plug. This got it out, but not before putting a very attractive twist in the 3/8th bar!
Why this filler plug doesn't have a standard 13mm square socket in it like all the other filler plugs is one of the great Defender mysteries - or is it charm? |
Well done you - sadly mine is still stuck in place - will get someone to try the welded bar approach next!1
Agree with you totally about the T55 head plug Is it possible to replace this with a standard square socket plug as used elsewhere? |
Only likely contender for an alternative filler plug is the one on the transfer box. I'll check this out when I get the TD5 over the pit for an engine oil change in a few weeks time and report back here. Don't hold your breath though!
Sad to say the the gearbox filler plug is a "one-off" and can't be exchanged with any of the other filler/drain plugs on a Defender - at least not any on mine. Thank you JLR! 1999 Defender 90 TD5
Thanks for checking this out for me - will ensure genuine LR plug replaces the damaged one
