Home > Maintenance & Modifications > LED light sets
Page 2 of 2 <12
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Thanks !
Thumbs Up Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #540127 14th Jun 2016 5:36pm
CarMan
I'm beginning to feel that I am overthinking this now, but I want a set of 11 lights in traditional colours for my Puma (4x indicators, 4x side, fog, reversing and number plate) + relay but happy to put a kit together myself if I have to.
I would prefer WIPAC as it feels more OEM compared to RDX and I certainly want it all plug and play with pre-wired connectors and am happy to pay a little more for that if necessary.
But I am struggling with vague ad wording to decide on best supplier so any help appreciated.
Thumbs Up
Post #551441 26th Jul 2016 7:58pm
redline
Switzerland
CarMan - I know the thread is old, but am wondering what you ended up with?
Like you, I am finding the website ads quite vague, and am having a hard time finding the kit that fits my needs.
Post #678419 14th Jan 2018 6:24pm
Cupboard
http://www.island-4x4.co.uk/light-defender...28044.html
That gives you most things, then you add the fog and reverse:
http://www.island-4x4.co.uk/light-wipac-xf...27366.html
http://www.island-4x4.co.uk/reverse-light-...27365.html
and the side indicators and centre brake light:
http://www.4x4overlander.com/product/led-s...-defender/
http://www.4x4overlander.com/product/defender-led-brake-light/
The Wipac relay is sensitive enough to notice if you have a trailer with LED indicators providing you set it up carefully. If you don't set it up carefully then it won't. With the engine running (that's important) put the turn signal on and gradually tweak the control until the trailer warning just goes out. If you do it using the hazard lights or with the engine off then you'll set it to the wrong place and it won't detect LED trailer lights properly.
Post #678430 14th Jan 2018 6:57pm
Nadine90
Wales 1986 Defender 90 300 Tdi CSW Fuji White
You tried defenderupgrades ?
Post #678448 14th Jan 2018 7:31pm
Sulisuli
Isn’t that your company Nadine? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #678455 14th Jan 2018 7:39pm
CarMan
I ended up with a mix, though coincidentally as posted earlier today I am keen to find a noisier indicator relay.
I wanted to keep the traditional look with a modern (LED) twist so finally ended up with:
WIPAC side lights, brake, fog, reverse lights & RDX dark side repeaters Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #678460 14th Jan 2018 7:54pm
redline
Switzerland
@Cupboard - thanks for the links, and particularly for the info regarding the trailer - I had no idea this could be an issue! I'm assuming there is a control on the relay that needs to be adjusted as you describe?
@Nadine - i did look at the site you mentioned, but didn't have the combination I am after. As Sulisuli mentioned; if its your site, in the interest of transparency and good form, you should mention it.
@Carman - thanks for the info. Looks like I will follow the same route, getting what I need separately.
Post #678481 14th Jan 2018 8:35pm
Page 2 of 2 <12
