![]() | Home > In Car Electronics > Would a DAB aerial receive FM too? |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
No.
You can get combined FM/DAB aerials though, we have one on the 90, it has both outputs/connectors. http://www.yorkshireoffroadclub.net/ |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Try dabonwheels.co.uk
I bought new DAB head unit and then bought DAB ariel from these guys. It's combined DAB and FM (two connections plus power connection) I got a bee sting type and roof mounted, fantastic reception, even when I unscrew the mast I think it was around 65 quid |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
Excrement, thanks guys
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
You can even get a box to make the fm one get dab
Yep, did debate that, but think I want one with a screen and has satnav built-in etc.
Sorry i meant you can get a box to make the FM Aerial be the receiving aerial for DAB, so not requiring a 2nd antenna - i appreciate it looked like i was talking about the head unit...that's a personal thing, i probably would change the head unit (or at least be tempted if there wasnt a reason to keep it) Mike
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20595 ![]() ![]() |
Well that is one way to thank people. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
With regards to this thread, i am running my kenwood dab radio through my standard telescopic aerial with amazing results, as recommended to do by my local car audio store.
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Mine too, use standard aerial, they fitted a power splitter. Apparently because defender aerial is so simp,e this works.
Find it works really well and all standard from outside, nothing stuck to Windows and no second aerial. James |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
I have a dab head unit and replaced the aerial for this
http://caraudiosecurity.com/hal2-external-body-mount-dab-antenna It works great for Dab and FM Oh and fits in the existing aerial hole Russell 2011MY 110 XS USW Black |
Thanks all, problem is I don't have an aerial full stop...or aerial hole come to think of it
![]() Discovery 3 HSE |
