Home > Puma (Tdci) > Clutch |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Def get the release bearing and slave changed.. The spigot shouldn't need changing, just a dose of grease..
While you are at it, get the gearbox extension shaft and splined socket checked between the GB and TB.. Might as well get any dry splines lubed before it wears away.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
10th May 2016 6:18pm |
