Home > Td5 > Todays job - Straight through exhaust - Td5
Lucifus
So since I've had the 110 Td5 I've had the Alive stage 2 map with de-cat and centre box removal. I was only running the small rear silencer in the system and it sounded pretty good. Not too noisy at all except when flooring it.
I've been running a straight through 3" bore on my 200tdi 110 for a few years now and it's certainly not loud and sounds pretty mean. So today I thought I would give it a go and remove the rear section from my td5 all together.
Now I'm not a pro welder by any means so please don't start commenting on my welds Laughing
I've welded in a piece of stainless pipe as that's what I happened to ahve left in my metal scrap pile. I've also give it a quick coat of paint on the welds to hold off the rust.
The result -
I've taken it around the block and it seems ok. It's certainly a bit louder that my 200tdi but not obscene by any standards like a boy racer. It gives a meaningful growl under heavy acceleration and it fairly tame when cruising. I'm sure it's not to everyone taste. I'll run it for a bit like this and if I change my mind then I can always weld the silencer back on lol
Post #529748 7th May 2016 2:50pm
chinnus
2001 Defender 90 Td5 ST Coniston Green
be careful the turbo has enough back pressure to fire up!
Post #530380 10th May 2016 2:02pm
Fatboy Slim
Wales
The turbine in the turbo creates all the back pressure the engine will ever need. You just want to get rid of the gas once it's out of the turbo for performance and efficiency Thumbs Up
Got a straight through on my 110 it sounds luuuush Thumbs Up
Post #530382 10th May 2016 2:10pm
mk1collector
Does anyone sell the rear section without the box? Ray
My build thread
Post #530387 10th May 2016 2:52pm
Lucifus
Nobody sells one that I'm aware of
Post #530389 10th May 2016 3:04pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I did the decat and middle box delete on mine a couple of weekends back, it has made a massive improvement to the vehicle and I'm really pleased I did it. It does sound superb, but its pretty loud..... does the backbox delete not make it TOO loud?
Post #530390 10th May 2016 3:15pm
Lucifus
It does make it a bit louder 😀
Post #530391 10th May 2016 3:20pm
Lucifus
I unbolted the rear section and took it for a drive to gauge how loud it would be before I committed to cutting and welding.
Post #530392 10th May 2016 3:22pm
miker
I have a welder. And a td5. I may have to remove my middle box! Also a '99 so no cats in the way either!
Post #530405 10th May 2016 5:09pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
I've been thinking of removing my middle box as its so big every time I go off roading it grounds out Rolling Eyes
The rear box also looks a bit vulnerable but I've not clouted it yet. '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #530406 10th May 2016 5:19pm
Lucifus
You can buy off the shelf straight through centre boxes. It certainly sounds good with just the rear box only. The rear box takes it to the next level of growl.
Post #530408 10th May 2016 5:35pm
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
Done the same with my 110, not much louder without the rear bean can but a bit more pronounced turbo whistle Thumbs Up 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
Post #532166 16th May 2016 8:38pm
chinnus
can you post a video of the growl lucifus?
Tom
Post #532400 17th May 2016 4:05pm
Lucifus
It's been a few weeks and I've driven it a few hundred miles. I've come to the conclusion that it's a lot louder on the outside than I thought. Had a few friends follow me with their windows open and they commented that it sounded loud when booting it but awesome! Under mild acceleration and cursing it's fine. Under full throttle full boost it's a beast.
Sorry although I have a go pro I don't have a mount to attach to the outside of the car.
Post #538311 7th Jun 2016 8:20pm
lightning
I have not had such good results with my 110 TD5.
I removed the CAT and fitted a straight through pipe, it did seem a bit better as in not actually any faster but the turbo spooled up quicker.
However when on the motorway there was a fairly loud resonance/drone at 65-70 mph which was tiring after a while, so l ended up refitting the CAT.
The rest of the exhaust is standard and 11 years old, so l wonder if my silencers are OK? As nobody else has complained of this issue after CAT removal.
Post #541093 17th Jun 2016 5:31pm
